Mapp gas?
I know that oxy-acetylene is advised for use in the removal of exhaust studs.
But I don't think I will have access to a setup without loading my engine up & hauling it to a shop.
My buddy suggested trying a mapp gas setup. Bottles are availible at lowe's for under $10, and its basically the same setup as with a propane bottle. I've read that some torches will produce heat of 2000 deg F.
It seams like this would be hot enough to loosen up some studs.
Has anyone used anything aside from oxy-acetylene?
Chris
Old 07-27-2007, 11:34 AM
Friend of Warren
Lowes sells a set up that uses a mapp gas and oxygen tank with kind of a mini welding torch and hose. I think it was only $30.00 or so. I used it successfully on my '72 exhaust studs. The down side is that the oxygen tanks don't hold much and as I recall I used up 3 of the oxygen tanks to one mapp gas tank.
Kurt V
Old 07-27-2007, 11:42 AM
mapp only burns at a slightly lower temp then oxy acet.
it'll work.
Old 07-27-2007, 11:45 AM
Evolved
Mo_Gearhead's Avatar
I.M.O. For someone that just needs 'heat' occasionally for loosening studs/bolts etc., or for brazing, go for the lesser cost Mapps gas sets.
Don't fear the reaper.
Old 07-27-2007, 11:46 AM
kplackmeyer's Avatar
+1 on the MAPP/O2 setup. Have one, and it works well for occasional brazing and torching.
Kerry Plackmeyer
1975 911s
Old 07-27-2007, 11:52 AM
awesome
thanks for help guys.
I've got 6 studs left in the heads. Original, w/ the narrow tapered section between the threaded portions. I got a good grip on one last night w/ a vice grip & started to turn and could see that thing twisting, but it was not turning out of the head. So I stopped.
Wish me luck, I hope this doesn't get to nasty.
Any one got one of those drill guides they want to lend/rent or sell?
~Chris
Old 07-27-2007, 11:53 AM
SP2 SP2 is offline
SP2's Avatar
I used the small Mapp canister type torch from Home Depot, etc and got all of my exhaust nuts cherry red before removal. The key is to have the allen head in position and as soon as you get it cherry red, torque the nut off. If you let it cool for even a few seconds it is less likely to work.
James
1969 911E Slate Grey
1981 911SC Wine Red
1997 911C4S Ocean Blue
Old 07-27-2007, 01:13 PM
I bought one of those mini Mapp gas set up's last year. Will someone provide me a link on how to heat things up for stud removal. I've not done it before and feel I need an article of sorts.
Old 07-27-2007, 01:20 PM
~Chris
In my experience, this is what happens right before the stud breaks. If you've twisted it, then the metal is weakened and will likely snap. Not your fault though, it's just inevitable. I hand drilled several studs without a jig and while it wasn't fun, it really wasn't all that bad. Track down the jig and you'll be just fine.
Old 07-27-2007, 01:49 PM
Senior Member
Superman's Avatar
The jig is great. Patience is KEY.
For those studs that might still behave, get the nut CHERRY RED and then quickly put the wrench on it and turn slightly clockwise first, then unscrew. The MAPP/OXY setup is very nice. The very small nozzle that comes with that kit is a nice size for those exhaust nuts. They will be CHERRY RED in a short time.
Mocha 1978 911SC. "Coco"
Old 07-27-2007, 01:55 PM
now drunk & and waiting several hours to guide a raft....
bear with me....just to clarify, exhaust off, all nuts off, & the engine is sitting upside down, on a table back at the house....Monday night, I will try double nutting on the studs, with a box end on the lower nut. I'll tighten the nuts against each other, heat the head as hot as I feel solid about.....mabye rap on the end of the nut lightly with a hammer,.....reheat & then try to back the stud out....?
Or should I try just gripping with a vice grip & backing off that way?
For almost the past two months, I've been at points where if I proceeded & messed it up, I could always just go back, & put it all toghether & it would run.....
I feel as if this is a point of no return.....But then again, come monday aftenoon, that **** will hopefully be glowing red hot!
suggestions?
Old 07-27-2007, 08:05 PM
