Mounting an Optima battery
I understand that someone wrote up a procedure for mounting an Optima battery in an older 911 (mine is an '80 SC), but it is NLA on the Pelican site. It uses a plastic cutting board mounted to the bottom of the battery with four bolts & nuts, and to the floor of the tub with a bolt to the stock mounting hole.
Do any of you have this article, the cutting board template, and/or the correct battery part number? I understand that it is best to get the correct battery so that the poles are not reversed.
Please email what you have to dbryant@structural-integrity.net.
Thanks,
Don
Don Bryant
1980 911SC
Old 06-08-2007, 12:07 PM
A Marchand fan before you
Por_sha911's Avatar
It was a thread written. Search button is your friend.
Joe
Old 06-08-2007, 06:49 PM
billroth's Avatar
1985 911 Coupe Black
1985 911 Cab GP White (killed)
Old 06-08-2007, 09:33 PM
KCinBR's Avatar
Here's a few pics of my install...may help.
KC
88 Guards Red Targa (sadly sold )
2005 Boxster S
1st Porsche 73 914 (long gone)
Old 06-09-2007, 01:18 PM
Put a cover on that red ( positive) terminal !!!....
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 06-10-2007, 10:39 AM
Diss Member
Quicksilver's Avatar
- Wil
Geeze...
You never like exciting things do you!
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 06-10-2007, 12:40 PM
I've once had the "excitement" of a $3000 electrical dash fire in one of my cars...don't need that again, thank you !!
- Wil
Wil Ferch
Old 06-10-2007, 01:48 PM
KCinBR's Avatar
- Wil
Yep, I do need to cover that terminal.
Thanks Wil, I appreciate your input and always place high value on the info in your posts.
KC
2005 Boxster S
Old 06-10-2007, 04:43 PM
Just in my "forewarned is fore-armed" mode ....
Hate to see others suffer like-kind issues.
- Wil
Wil Ferch
Old 06-11-2007, 06:58 AM
TroyGT's Avatar
I did this and it worked great with my Optima red-top battery. My cutting board came from walmart and was black w/flecks in it. Very fashionable and cheap and functional and easy.
-Troy
1986 911 Coupe (Guards Red), Fabspeed Euro Pre-muffler,
Steve Wong Performance Chip
2001 Boxster 2.7L (Orient Red), bone stock
Old 06-11-2007, 07:47 AM
Less brakes, more gas!
euro911sc's Avatar
Made mine out of Aluminum.
-Michael
Michael
FOR SALE:
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'03 330i Family hauler w/ extras
Old 06-11-2007, 07:56 AM
MIK911's Avatar
nice
Mike
'86 911 coupe
'85 BMW 535i
'11 Cayenne
Old 06-06-2009, 11:35 PM
rbuswell's Avatar
Porsche Crest Part Source
- Wil
- Wil
Wil:
Mine has several other wires attached to the positive terminal to get direct power (all with their own fuse and relays as needed) rather than run them through the fuse panel. Is there a good cover I should be looking for that would do the job and cover all the extra wire connectors? Thanks.
1982 911SC Coupe (Zinc Metallic w/ Dark Blue interior)
1987 924S (Black on Black)
Old 06-07-2009, 07:42 AM
I just now saw your ( rbuswell) question.....
I too have an Optima install and do have the pos cable covered. I bought a cablecover red "bootie" from the FLAPS...and had to cut/slice it, and then zip-tie it into place to be an effective cover. Still not what I think is a first-class looking solution....I may soon be looking for the semi-transparent tupperware containers and see if I can find one to modify that is close to the size of the whole battery top itself !.....work still in progress. Nonetheless....any effective insulation material, mounted properly, should work.
Wil Ferch
Old 06-13-2009, 06:35 PM
nineball's Avatar
depending on how many connections you have and what gauge wire they are you may find something here to use.
http://www.knukonceptz.com/productMaster.cfm?Category=Battery%20Terminals
i use the lower set on one of my other cars and love it, but i used 0g wire with that setup. fast shipping and reasonably priced quality products.
Old 06-20-2009, 07:18 AM
Throw it on the ground!
You might want to add a cutoff switch - on my to do list. I like this install.
Mark
1987 911 Coupe
Granite Green Metallic
Happy Birthday to the Ground:
http://www.funnyordie.com/videos/e4e2187156/andy-samberg-i-threw-it-on-the-ground
Old 06-20-2009, 07:31 AM
