Wer bremst verliert
JohnJL's Avatar
Engine Build Dyno Results
So I finally got the results of my year-long engine build and install. The engine itself was done within a few weeks but the rest of the car took a while.
The engine has been run in and done a about 200kms at a few track days and a Supersprint.
I was hoping for a bit more power but I'm pretty happy with the torque curve, even if it lets off a bit early. You can see it was still making more HP at my self-imposed 6700 RPM. The dyno gear calibration was a bit low so it shows RPM about 100 low on the chart. I have standard valve springs in there so I am a bit wary of going much higher unless someone wants to endorse that...
I suspect the heads may be the limiting factor since the fuel/air mixture is spot-on and we spent quite a bit of time working on the spark map.
My fuel/spark maps are available for interested parties, e-mail me.
US 1983 34mm intake/35mm exhaust port heads. The intakes were taken out to 36.7mm and blended to the intake manifold.
3.2 Carrera aluminum intake & throttle body.
K&N filtercharger from a cummins diesel kit.
11:1 JE pistons
3.0 standard cylinders 95mm
SC crank.
US 1983 SC case, boat-tailed
twin-plugged fully controlled by ECU
Dougherty DR20 cams
Twin EDIS 6-post coils driven by triple-channel igniters
Innovate LC-1
26lb/hr Accel injectors @ 40lbs fuel pressure
rising-rate Edelbrock regulator
standard sc fuel pump
2-into-2 flowmaster muffler
bursch headers
Adaptronic ECU
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 06-10-2007, 12:11 AM
John
Great to hear it has all come together.
How did your ignition maps end up?
Can you provide more detail on the Dyno results?
Paul
Old 06-10-2007, 01:14 AM
Wer bremst verliert
JohnJL's Avatar
First is the HP/Torque at the wheels.
Second is KW and air/fuel ratios.
as soon as youtube posts the videos I'lll post those urls too
Old 06-10-2007, 01:40 AM
Wer bremst verliert
JohnJL's Avatar
www.youtube.com files:
Dyno clip
Dyno run to redline
Old 06-10-2007, 01:46 AM
mack6820's Avatar
Heres a question. How do they get the numbers on the dyno. Do they try it in all gears or is it a certain gear they go to redline with?
Certified Southern Dumbass!
83 911SC with 993 conversion,
98 Ford Expedition 4WD lifted beast, 98 Jeep Grand Cherokee, 01 Ford Taurus, 99 Nitro Bass boat, and a riding lawn mower
Old 06-10-2007, 06:20 AM
ttweed's Avatar
My dyno operator selects the gear that gives a drive ratio closest to 1:1. On a stock SC 915, this would probably be 4th gear, as 5th is pretty tall and an "overdrive" gear, if I recall correctly.
176 RWHP does seem kind of low for all the mods to this engine. Does the Dyno Dynamics generally give lower readings than a Dynojet? I pulled 168 RWHP with a well-worn, stock '82SC motor on a Dynojet 248C a few years ago. An 8 HP difference doesn't add up considering the higher compression and intake mods, twin-plugging, etc.
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 06-10-2007, 07:51 AM
Plavan's Avatar
Yeah. that seems low with all those changes.
As a reference my 2.5L motor with 10.5:1 pistons, single plug with 46mm PMO's put out 217HP at the rear wheels.
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 06-10-2007, 09:01 AM
Mark S
I concur it's low. My 81x66 twin plug, 40MM Webers, 10:1, 208 @ rear.
Old 06-10-2007, 09:31 AM
mack6820's Avatar
Does the weight of the car play into a horsepower reading? Seems like a lighter car would produce more power to the pavement correct? Im not into physics, just trying to comprehend.
Old 06-10-2007, 01:26 PM
randywebb's Avatar
no, it will just feel like it.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 06-10-2007, 01:31 PM
mack6820's Avatar
Please forgive me... So in turn, a lighter car with less Hp could beat a heavier car with more HP. I guess it makes sense now. My car would definitly beat my SUV. hehe
Old 06-10-2007, 01:35 PM
Wer bremst verliert
JohnJL's Avatar
There is a significant difference in dynos, between companies, models, even the same models. I'm not so much worried about the absolute number as in comparisons to mods as I make them. An added bonus is these certified runs will help keep my power/weight ratio classification in a group I can be competitive in. The car, wet with me in it, at the starting line is 1040kgs.
I was also still making power up high and I suspect I'd hit higher numbers if I was wanted to push the redline up. I have new but OEM rod bolts and valve springs so I didnt want to push it.
The ratios and spark is well dialed-innow so the only real way to get more power now is through a mechanical change and that would mean the heads, bolts and springs. And displacement and boost (my other project). The Tech and I traded wearing the Det-Cans and we were never able to induce knock. The twin-plugging as I understand it won't get me any more horsies, just made it possible to keep adjusting the spark angle more and more advanced until power fell off. We then backed it off 2 degrees and did a few more pulls at that RPM and load again. If I wasn't twin-plugged at those high-compressions I might have been knocking before I got to the point of max power/spark angle. High compression and hot Australian track temps exacerbate the risk. Anyway, thats what the Internet told me.
To tell the truth (or maybe I'm in denial!) I'd really mostly happy the engine held together as it was my first full engine design and build. It gives me some confidence on the next project and in that case I've already made different decisions on that.
This is my first real race car so while I started out wanting a fire-breathing monster, but now having some seat time on a few different tracks and really starting to understand how the cars behaves (and a spin or two!) I am really happy with what I've ended up with: a very quick, reliable, easy-to-handle car that makes some awesome noise and gets attention at all the meets. The torque curve is quite broad, the scale on the graph at the top is a bit deceptive. It is very communicative and the combination of tires (Toyo RA1) and suspension/settings (Elephant Racing/Tarrett) makes it very "tactile." Instructors like the car too and it makes it easy to learn in...the throttle-position and brake LEDS show exactly what I'm doing and can be seen periphally while watching the road, you can hear EXACTLY what the engine is doing, and the cage/seat/harness system is very robust and comfy.
Anyway, so the absolute HP numbers don't thrill - 203 at the flywheel - but perhaps it will give others an example of what my build resulted in or maybe someone has a magic idea about how to find me another 30 hp?
Old 06-10-2007, 03:24 PM
John
Don't be too concerned with the Dyno results.
It is my understanding that the US chassis dynos are calibrated higher than the Australian chassis dynos. There is extensive background to support this difference in calibration.
For flywheel HP apply the following factors.
Flywheel HP = US Chassis Dyno * 1.15
Flywheel HP = Aus Chassis Dyno * 1.32
You did not respond to my earlier question re: the ignition map. How did the final map compare to the detail I provided earlier? Were you able to get more advance?
Paul
Old 06-10-2007, 03:27 PM
Wer bremst verliert
JohnJL's Avatar
Thank Paul. Sorry, I must have missed your question. I did indeed start from your map, thanks so much. I did get some more advance but only a degree or two before power fell off. I did change the slope a bit. My ECU doesnt like to cut and paste maps...
10 deg cranking
15 deg 1000 rpm
16.8 deg 2000 rpm
25.2 deg 3000 rpm
27.2 deg 4000 rpm
28.2 deg 5750 rpm
29.2 deg 6000 rpm
30.2 deg 6250 rpm +
Those are all at WOT. at partial throttle I am sometimes advanced as 35 deg at 6000 rpm 0% throttle.
BTW, thanks. Your calc gives me 237hp, which is up 60 from stock. I'll choose to believe that number ;-)
Old 06-10-2007, 04:08 PM
John,
Your dyno results will also change depending on humidity and temp as well as heat soak on the day you tested.
My two cents
Michael
Old 06-10-2007, 05:01 PM
Hi John, well done.
I can definitley vouch for the low readings on Australian Dyno Dynamics chassis dynos.
I have a stock '84 Aust. delivered 3.2 Carrera which I had dynoed to get a baseline in case I decide to do some mods.
The result came back very disappointing, 155 RWHP which is not indicative of the car's performance. I'll post it up. Using the x 1.32 mentioned by John (Cruisesontrol) brings me to around 205 at the crank. I know this car personally is a 3.0 stock SC eater by a significant margin and also used to beat my friends 3.0 Carrera any day of the week.
I track the car reasonably regularly and last meet at Wakefield park I was arm-wrestling a slightly modded '78 3.3 930 with aftermarket turbo and RUF 5-speed. He was undoubtedly quicker down the straights but not shamingly so.
I later realized that (like many other Carreras) that my throttle linkage was poorly adjusted not allowing full throttle. I tested the WOT switch and it was being actuated. Maybe I was missing out on some indution air but I think I'll re-do it again now and let you know if interested.
BTW are you doing any PCNSW events?
Phil
cheers,
Phil
84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies.
Old 06-10-2007, 05:37 PM
cheers,
Phil
Old 06-10-2007, 05:41 PM
John, thanks for the feedback on the ignition timing.
In response to Michael's post, I was told many years ago that HP difference relative to temperature is about +1% per 10degF (5.55degC) fall in temp.
Maybe, some one else could comment and also relate to the changes relative to humidity.
Paul
Old 06-10-2007, 05:46 PM
Hi John,
Congrats on your motor. Don't worry about the low #'s. The DynoDynamic and Dynapac dynos both give lower #'s than other dynos.
Do you like your ECU? And what made you choose that brand?
Dean
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 06-10-2007, 07:02 PM
Wer bremst verliert
JohnJL's Avatar
Hi guys, thanks for the comparisons.
It was 16 degrees and 54% humidity so the conditions were good for the runs. I did get my #4 head temp up to 310F so let it cool off but even then I was getting repeatable results.
Hi Phil, thanks for those. Yes, I've been doing some PCNSW activities. My car is track-only so I've not been doing any road events but I was down at Wakefield last month for the SUpersprint, to the Hi-tech muffler factory sizzle and to two Driving Solutions days. Went out to Alan's for the swap meet too.
Dean,
The ECU is Adaptronics, go to www.adaptronics.com.au I chose him because 1. his system does everything Haltech, MoTec, MSII and others do, 2. it cost me US$ 750.00, 3. the designer and company owner lives around the corner from me and 4. he does house-calls to install and troubleshoot. Plus he's a really nice guy. Oh, and he can build in custom features for you. Like for me he built in bluetooth so I can monitor, program and datalog the ECU from the laptop on my workbench.
I also built a megasquirt and will play with that some more.
Old 06-10-2007, 11:09 PM
