Evolved
Mo_Gearhead's Avatar
Oil Tank Breather?
Just finishing up my restoration. Have Webers with K&N filters (ok, those K&N filter HATERS, save the flaming ...I am keeping them).
Have installed the hose from the engine breather back over to the oil tank. That leaves me with the same size vent tube, open at the oil filler neck. I want to run that hose back up under the package shelf (protected from water) with some sort of
"breather" attached to that end and a bracket to locate it.
If you are running Webers/ PMO, show me pics (or explain) how you solved the oil tank vent issue please.
Thanks.
Don't fear the reaper.
Old 06-11-2007, 06:09 AM
Do a search on oil catch can and you should find some pics.
Old 06-11-2007, 06:45 AM
Evolved
Thanks JP... several ideas there. Looks like I'll just fabricate up something.
Old 06-11-2007, 07:29 AM
randywebb's Avatar
if you do something different, post the results.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 06-11-2007, 12:03 PM
