help needed: installing an amps instrument
Hi,
I had to realise that the instructions that came with the amps instrument I bought for my early 911 do not apply to Porsche. Anyone have experience with installing these and can give me instructions on how I should do this? Thanks! Anthony |
Anthony, here's a start. Some experts replied to my thread, so you might try contacting them directly in case they miss your inquiry.
Bill K http://forums.pelicanparts.com/porsche-911-technical-forum/336140-volt-meter-vs-amp-meter.html |
you basically run an amp meter between the big red wire on the alternator and the + battery terminal. so you would have to cut that circuit somewhere and extend the wiring up to the dash mounted amp gauge. not really a good idea.
| All times are GMT -8. The time now is 11:19 PM. |
