Immature Member
Follow-up question: Just to clarify... if I want to check that my brake pad wear indicator is working, do I just attach an alligator clip to one of the leads to the pad sensors and ground it out? I guess the rotor itself is the normal ground source?
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" Last edited by dentist90; 06-11-2007 at 09:03 PM.. |
1. The brake wear sensor system in 84-89 Carreras is NOT a single wire grounding system. It is a 2 wire open circuit detection system that will also work if the sensor wire is grounded. 2. The e-brake/low fluid level warning circuit is separate from the pad wear sensor circuit. I've seen some confusion between the two, thinking that both systems operate the same light. They don't. Having the e-brake on or the fluid level lights up the light the says "BRAKE". The pad wear sensor lights up the circle with 6 dotted lines around it. Low oil pressure lights them both up via a diode based "OR" circuit. What do I have to back this up? Factory wiring diagrams, the internal schematic of the brake warning system, experience with my own 85 Carrera and a rusty but still valid EE degree. From the factory diagram you can see that the system consists of a single wire loop with all sensors in series: ![]() I was familiar with this circuit because I just this weekend removed my wear sensor circuit, as my car is a mostly track car and the pads I run don't have sensor cut outs (and would probably melt them if they did). If this was a single wire grounding system, I doubt Porsche would have run the series loop like they did. But, Porsche engineers have done weird things before, to lets look inside the circuit. So how does it work? The basic premise is that when the pads get low, they'll wear through the sensor wire and sever it, creating an open circuit between pins 1 and 2 of the 3 light module. Inside, it's a very simple circuit that biases on a NPN transistor to turn the light off when the system is intact: ![]() Pins 1-2 close the circuit between the 750 and the 1.6k resistors. So, when the loop is intact, there is ~ 9V at the base of the transistor, turning it on. When the transistor is on, it grounds the gate of an SCR, keeping it off. The SCR is what actually controls the light. When it's on, the light is on. If the circuit between pins 1-2 is open - or grounded - the base voltage will drop to zero, turning the transistor off. This turns on the SCR which turns the light on. The oil pressure switch is simply diode-ORed to both brake warning lights at the end of the circuit, but has nothing to do with the open circuit detection part of the circuit at all. So yes, it does work if you ground the sensor wire, but this is not it's primary mode of operation. Fundamentally it's designed to detect an open circuit. Why do I say that? Well... Quote:
For this system to be a single wire ground design, a significant portion of the wear sensor itself would need to be conductive to make reliable rotor contact as the pad wore. That's not the case with the sensors on these cars. Quote:
I love this forum, the fact that after 4 years of owning this car there are still things I continue to learn. Albeit, sometimes I have this obsession to go beyond a point that could be considered reasonable and prudent by a sane individual
![]() Jazzbass - that is a great detailed explination & diagram of the internals of the circuit, but I think I have to respectfully disagree with your conclusion: Quote:
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic Last edited by aj88cab; 06-12-2007 at 05:09 AM.. |
The sensor is a small piece of non-conductive plastic with an insulated loop of wire in it. The wire is not secured in the loop. It won't take long for the rotor to wear through the wire. Yeah, while it's wearing through the wire it's probably grounding on the rotor. But, the wire is a small 18ga wire and that would probably take 3-4 brake applications before it wears through - maybe less. Now, at this point the circuit is open, maybe occasionally grounding through the rotor is one of the loose ends of wire in the sensor just happens to randomly contact the rotor. But, no engineer in the world will design a sensor based on random contact as it's primary trigger method. That's why I say open circuit mode is the main design - grounding operation occurs 4 out of potentially hundreds of inputs and then randomly after that is maybe 10% of time it detects th pads are low. The other 90% of the time is all open circuit. There are one-wire grounding systems that detect brake wear primarily via grounding to the rotor. This one isn't one of them. In these grounding systems, the entire sensor has a large conductive area to ensure reliable and repeatable electrical contact with the rotor. That is simply not the case with the Carrera sensors. |
jazzbass,
No real argument with your conclusions. The good news is we now know that there are two modes that can trigger the warning lamp. Yet another "Porsche Engineered" system demystified ![]()
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic |
Is this the actual circuit that is in the car? Just want to add to my collection. Off to the right is just an SCR and a bulb?
Makes sense. Quote:
I might be splitting hairs here, but some folks do make a distiction between "igintion on" and "engine running". In this case the engine must be running, disconnecting the connector should turn the warning light on. Reconnect and the light will stay on until the engine is turned off.
This is the discussion I've been looking for re:the brake pad sensor circuit.
My question at this point is the proper removal of the module from the dash of my '85. I have accessed the rear of the module by removing the clock and speedo. At this point I have disconnected the connector at the rear and pushed the module from the rear by hand. Is there some kind of retainer to be squeezed before removing the module? Thanks jazzbass for your clear documented explanation of this circuit. Better than that found in my Bentley.
DOUG '76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's. '85 911 Carrera, stock, just painted, Orient Red |
Immature Member
Exactly what I was thinking. Having the circuit broken forces you to tend to the pads or the light will not extinguish. A ground- indicating system would cause the light to flicker but be mostly off.
Another question: if one were to replace the pads before the light comes on, do you re-use the old sensors or get new ones anyway? Similarly, if your light comes on, but it turns out only one sensor has worn thru, must you replace all of them?
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" |
Dear JazzBass, thanks for suberb enlightenment on this - I've been trying to solve the mystery for a while.
Thanks to you, I've carefully removed the light unit from the dash, bridged pins #1  and my light has gone out. Thanks! |
Glad it helped
Brake Pad Wear Sensors...
Who's on first... I removed the pig tail that connects to the brake pad, installed a plastic plug into the female plug end that mounts to the strut and trailing arm. Dash light stayed on. Then I read you need to complete the circuit so I cut the old pig tail off leaving enough to twist the TWO wires together, found a perfect cap to fit over the bare wires and plugged the plug back into the female socket. Dash light stays on...
What am I doing wrong???? Thanks,
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
Sound like you did everything correct. Make sure you turn the ignition off then on agan. The only thing I can think of is that one of the twisted wires came loose when you attached the cap or one of the connectors is bad or dirty. A short somewhere else in the circuit is always possible. Low fluid could do it too but that would be too easy....even easier would be if it was the parking brake light you were seeing....Don't mean to insult your intellegence with those last two, just looking for options
![]() Was the light off before you removed the wear sensors?
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic Last edited by aj88cab; 05-23-2008 at 01:59 PM.. |
Thread Tools | |
Rate This Thread | |
