'87 3.2 spark plug recommendation??
Looking for advice of which plugs to get? Any recommendations for my '87 3.2L?
Thanks.
- Sean '87 Carrera |
Dar - 88 Carrera Coupe "Schotzie" Grand Prix White DIY Upgrades: SW chip, M&K 1in/1out, Bilstein HDs, 17" Turbo Twist 9s&7s, Spring-center clutch, No-Drill Release fork shaft update. |
I'm going to give you the short answer (but go ahead and read that link too): NGK BPR6ES is a great choice for your 3.2 but Boschs would be fine too. Forget about trying anything other than copper plugs.
Friend of Warren
Same as Keith: NGK BPR6ES
Kurt V No more Porsches, but a revolving number of motorcycles. |
I use Bosch platinum 4 #4477
Steve |
Thanks to all for your feedback.
I took the advice to get the NGK BPR6ES plugs and installed them. What a difference! I first noticed how quickly the car fired up. When it settled down, it became very apparent that the idle was smoother. The car also seems to be more responsive. When I pulled my other plugs out, I noticed that two of the six had a much smaller gap than the recommended gap of .028. Not sure how/why... this could have been the cause for a slightly rougher idle, not sure? It's hard to believe that such a small change can make such a big difference! Again, thanks for advice.
