-   -   window wiring CS 82 (http://forums.pelicanparts.com/porsche-911-technical-forum/351833-window-wiring-cs-82-a.html)
dependencies 06-13-2007 12:51 AM
window wiring SC 82
Anyone got that picture of the diag'
to hand I've got it in bits and forgotten now my own advice
bugger it all
dependencies 06-13-2007 02:51 AM
No?
OK then try another tack.
The fuse on the windows keeps blowing.
When I swap it,
both windows work, with their individual efficent speeds just as they have since I bought it Five years ago.
The manual 964 engine cover spoiler I retro-fitted works,
all is in fact fine....
I lock it up,
go for a coffee come back out, and as often as not
every time I go for riser switch
(and before the window has even moved at all)
its dead again.
Even took a spare battery from another car and hooked it all up directly without a fuse and it works fine,
Re-connected them as they should be to the car, via that last fuse on the board,
wag the door to & fro,
as they can chafe the wires there I know
its fine windows operate the whole time,
get out, leave it
come back
turn key
blown fuse...
any thoughts
dependencies 06-13-2007 05:40 AM
you lot are miserable today,
has someone nicked your wristwatches?:rolleyes:
