North Coast Cab's Avatar
Are All 11 Blade Fans the Same?
I have an early (901) alternator & housing and a later one (911). Both have 11 blade fans. Are the fans interchangeable? I know the alternators and housings are different, but I can't tell with the fans.
John
1985.5 944 GTS
Old 06-15-2007, 05:14 AM
John,
I think the actual castings are the same its the pulleys that are slighty different diameter and design. The early pully has 8 large holes in it. The later SC/turbo 11 blade has 16 small holes in it. I think the carrera pulley is also slotted. I know the pulleys can be removed and swapped around.
The last picture is the fan I have on my car. The early pulley was removed and replaced with a SC era pulley.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 06-15-2007, 07:12 AM
There are a couple different 11 blade fan outside diameters. I think the 78/9 SC has a smaller dia than others.
Do a search.
Old 06-15-2007, 09:03 AM
klaucke's Avatar
There are 3 different 11-blade fan diameters used over the years. There is the 226mm used in 78-79 SC, and the 245mm used on most other years (before and after 78-79), and there is the very early 250mm fan (debatable when this was used 1965-196X, X=6,7,8?).
Old 06-15-2007, 10:23 AM
Thanks. I am switching from a 901 set-up to a 911 Carrera set-up and I can't get a belt to fit. I have a 725 and a 710, but they are both too big. I run a Clewett trigger wheel which is slightly undersized.
I used a 710 on the 901 set-up, but it is too big on the 911 set-up using either one of the pullies.
1985.5 944 GTS
Old 06-15-2007, 11:48 AM
Yeah, sorry about that John..I thought we were just talking about the 245mm..and yes there was that oddball 250mm and the smaller 226mm
I'm using the larger 78/79 crank pulley and the smaller 80-83 fan pulley on my car. I'm using the original 78/ 79SC belt..725. For the record my fan was from a 901 housing. I just swapped the pulley. My current housing is a 930.106.102 0R that replaces the stock 78/79, 930-106-101-0R.
Peace, Ron
www.ronorlando.net
Old 06-15-2007, 12:37 PM
safe's Avatar
Originally posted by Mysterytrain
John,
Do you have any cast partnumber on those?
Magnus
Old 06-15-2007, 12:45 PM
