-   -   What size spacers do I need >? (http://forums.pelicanparts.com/porsche-911-technical-forum/352008-what-size-spacers-do-i-need.html)
Rad Hatter 06-13-2007 11:35 PM
I'm running 7's and 8's btw with 205/55R16 and 225/50R16 YOKO's and it's been lowered quite a bit. to 24.25 and 24.75.
What size spacers would I need to fill out the arches front and back?
I have uploaded some scans of the exsisting set up.
Appreciate your help on this one chaps
Richard
http://forums.pelicanparts.com/uploa...1181802669.jpg http://forums.pelicanparts.com/uploa...1181802749.jpg http://forums.pelicanparts.com/uploa...1181802777.jpg http://forums.pelicanparts.com/uploa...1181802798.jpg http://forums.pelicanparts.com/uploa...1181802829.jpg http://forums.pelicanparts.com/uploa...1181802852.jpg
Rad Hatter 06-14-2007 02:58 AM
bump
Zef 06-14-2007 02:59 AM
No more than 1 inche for the rear set up...
widgeon13 06-14-2007 03:23 AM
15mm is about all you can go IMHO, 21mm is too much but I have seen it done. Think 21mm will rub.
Dutchie 06-14-2007 03:37 AM
20 mm max maybe 1 inch would work if you roll the lips. The front is fine i woulden,t even try a spacer there i,m sure it will rubb. The best is to get a set of 9J fuchs for the rear offcourse ;)
Cheers,
widgeon13 06-14-2007 04:15 AM
9X16 will not change the appearance as the additional 1" is all on the inside of the rim (I believe).
I had 21mm on my car w/ 8's and it looked like ***** to me, so took them off and now have 15mm.
widgeon13 06-14-2007 04:45 AM
http://forums.pelicanparts.com/uploa...1181821467.jpg
This is what 21mm looks like from the side.
Rad Hatter 06-14-2007 06:52 AM
Thanks 15mm it is then
Thanks for the replies and photo
Cheers Richard
jevvy 06-14-2007 09:04 AM
You can use up to 7mm(os is it 9mm) shims front and back with standard studs, this is the cheapest option.
if you want more then you either need longer studs fitted or you have to buy adapters that bolt to your hubs and then bolt the wheels to the adapters.
Spacers:
http://www.type-911.co.uk/images/wheelaccess/ws7.jpg
Adapters:
http://www.type-911.co.uk/images/wheelaccess/ws26.jpg
I fitted 9mm shims all round as was quite pleased with the change.
Rad Hatter 06-14-2007 07:30 PM
Thanks buddy
GeorgeM 06-14-2007 10:04 PM
I got the H&R variety that come with longer studs that you need to swap out. For some reason, the studs were a bit too long and poked through my lug nuts (it only had to happen once).
So, I put an additional ~7m spacer on there to solve the problem.
Rad Hatter 06-14-2007 11:52 PM
good advice
Thanks for that
Richard
