3.2 Throttle Body Return Spring - replacement part???
I have a 3.2 intake/throttle body on my 3.3L turbo.
The return spring that wraps around the throttle shaft is broken/worn out, and if I open the throttle by hand, it will not snap shut. I need to replace that spring if possible. Does anyone know of a spring that can be purchased and installed on that throttle body, or is there somewhere I can send the TB to have it rebuilt? Brian |
Brian,
I don't believe that is the spring which closes the throttle. This is the spring which closes the throttle. Check out here. Throttle spring |
bring it down to Home Despot, they"ll have bags of them. Or better yet, your local hardware store.
| All times are GMT -8. The time now is 09:19 PM. |
