Rear sway bar attachment 911/930
I believe once upon a time I saw a drilled replacement eccentric bolt for the rear spring plate that allowed attachment of the Weltmeister aftermarket sway bar and drop links. Does this ring a bell to anyone out there?
I think this might be what you're referring to.
http://forums.pelicanparts.com/uploa...1181867349.jpg |
Yes Turk, the eccentric in your photo is what I'm looking for. I already have the drop links. I know I've seen these somewhere for about $40 bucks each, I just can't remember the source. I checked Weltmiester.com and Pelican but didn't see them there. Do you recall where you got yours?
I bought mine 20+ years ago from Automotion, they came as part of the Weltmiester rear 22mm sway bar kit.
I’d try getting someone from Weltmiester on the phone. Good luck. |
Tarrett carries them with the drop links.
http://www.tarett.com/items/911-series-products/911-suspension/911-rear-droplink-set-65-89-with-78-89-factory-swaybar-911rdlnk-detail.htm JP |
you can buy them from our host as a spare part- they will have to look it up. its not listed on the site
| All times are GMT -8. The time now is 12:40 AM. |
