Where do I find the door plugs for the window switch wires?
My window switches are not getting power. I have checked power at the fuse box, and up at the window delay relay (by the fuel guage), and it seems to be good. So somewhere between that relay and the window switch there is a disconnect. I have heard there is a connector plug somewhere in between the two, but I haven't been able to find it, please help!
I know its not the switches, because when I run power from the electric mirror to the switch they work fine. Car is an 87 Targa. Thanks! |
Near the hood hinges, there are large round holes that the connectors are generally tucked into. They are round white connectors with about 8 pins. Start with the left side as the right won't work unless the left does
There are two plugs inside the trunk. One on each side up near the hood hindge area. round and white in color.
Can I get to them without taking the door off? I saw the wires, but cannot figure out how to get to them with the door on. Or are they easily accessable from the hood?
Thanks! |
They come up into the trunk. Unplug the connectors and see if you have power there.
Good luck! |
| All times are GMT -8. The time now is 06:19 PM. |
