Hydraulic clutch on a 915
Has anyone heard of or done this type of modification? I would like to have this type of clutch on my SC, can anyone help?
78 911 SC "Scratchy" 2004 Mini Cooper S "Pele" (gone but not forgotten) 1979 classic mini clubman-"Coolio" |
Gon fix it with me hammer
not cheap
http://www.wevo.com/Products/ClutchProducts/915Products/WevoClutch915Products-Superlite.htm
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
This could be cobbled together pretty reasonable-- You just need a line, and appropriately sized master and slave cylinders. The VW and sand rail aftermarket is ripe with these products.
It's true that these products are out there, but to adapt these to a Porsche floor pan would require a custom pedal set, or a modified stock pedal assy. that would accept a hydrolic master cylinder. |
why mod the pedal cluster if you can get one from G50 car? should be plenty of em out there on salvage yards
I did this on my 72T, but I also got the benefit of power brakes. The pedal assy is much different and in my case required a replacement of the luggage tray. I had to cut out a section from a wreck and weld it in place to locate the new parts. Once this was done it was a simple replacement of the original parts w the G50 equivalent. I fitted a G50 trans so the slave cyl was already mounted. Perhaps the Wevo 915 bits could be used at the tranny end to simplify things. Not easy but doable. If I can find photos I will post them. Cheers, Len
