jj4u3's Avatar
Question rear brake grabbing
what would cause the rear brake to grab? I have a 1972 T and I was driving today on the highway and then when entering back to town I came up on a stop light and it felt like that I had a flat tire. I couldn't pull off the road immediately so continued on to the next light and the same thing when I put the brake on to slow down. I pulled over to discover that I didn't have a flat but my rim on the rear drivers side was hot. After letting everything cool off I continued home and had no more problems. I checked the brake fluid and was about three quarters of an inch low so I filled it up and put the car in its stall. What could be wrong? I have had this car about 2 years and only twice have I had to put brake fluid in it?
911 - 1972T
Old 07-08-2007, 07:26 PM
You should not be losing brake fluid ever. My guess your leaking fluid onto your pads, causing the lockups. Do not drive the car until you fix this. You are a brake failure/accident waiting to happen.
1974 911 targa 2.7 (for the road)
1974 FJ40 Landcruiser (for no roads)
1995 Dodge V-10 HD2500 4x4 (to tow anything I want)
2005 Durango (wifes rig, I've driven it twice)
2000 Fisher Freedom 200 w Mercury 115 ELPTO (because the world is mostly water)
Old 07-08-2007, 07:30 PM
