stuffed muffler problem
I just received another muffler and found that it was "stuffed" with pieces of cardboard, leaves and twigs in both chambers from the dual inlets. I also saw what looked like pieces of a small egg.
I think there was a small animal that lived in there once upon a time. I couldn't tell if there was a carcass in the muffler. The PO apparently had it in "storage" and decided to sell it.
It is in otherwise pretty good exterior condition.
Question: how do I safely clean it all out?
I was planning to run the muffler and burn it all out but I am concerned a fire issue and/or the contents being sucked into the the headers (is the latter an issue?).
Any ideas besides cutting the muffler open would be appreciated.
1989 Carrera 3.2 Silver Anniversary Edition
2007 BMW 750Li
2005 Honda Odyssey EX-L
http://forums.pelicanparts.com/porsche-911-technical-forum/285064-new-member-have-pics.html
Old 06-18-2007, 09:20 PM
fty fty is offline
fty's Avatar
Send a message via AIM to fty
Vacuum, tape a small diameter hose to the end of a vacuum and suck it all out...or shake vigorously
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD
04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP
http://www.eurocompulsion.net
Old 06-18-2007, 09:23 PM
You can also try to blow it out if you have a shop vac w/ that feature...
John A.
1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.)
05 Boxster S: For the Track.
06 Dodge Ram 2500 Power Wagon: Tow Vehicle
Old 06-18-2007, 09:42 PM
Duh...
Now why didn't I think of that? I guess I'm overthinking the problem.
I'll try both methods.
Thanks.
2007 BMW 750Li
http://forums.pelicanparts.com/showthread.php?s=&threadid=285064
Old 06-18-2007, 10:32 PM
MIK911's Avatar
Re: stuffed muffler problem
That's Hilarious. You have a whole ecosystem living in your muffler!
btw, do you have SSI's (headers). If so, do you have a 'favorite' smog test facility here in the SoBay?
thanks
Mike
'86 911 coupe
'85 BMW 535i
'11 Cayenne
Old 06-18-2007, 11:54 PM
just run it at idle for a bit to warm it up then rev it a bit it will blow out..
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 06-19-2007, 05:46 AM
