fan removal HELP
how do you
Its has a metal tab....what next...87 3.2 engine.
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD ![]() 04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP ![]() http://www.eurocompulsion.net |
UFLYICU
Drop the fan on top of two boards several times, it should pop out.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
yeah mine doesnt wanna come out, how does the alternator come out??
UFLYICU
It is a press fit. Once the nuts are removed around the edge, it should fall out with a few raps. Some resort to banging on the shaft with a BFH, but I've never had any problem with the method I posted above. You might try a little heat around the edge to see if the fan will expand enough to loosen it.
I beleive the above method works well removing the alternator form the housing, but he's asking about removing the fan.
Squirt some PB Blaster around the center bolt. You need to have it perfectly square to get it to slide off, and sometimes it takes some wiggling. I've even had to use a gear puller once to pull one off.
1985.5 944 GTS |
And when you get the fan off, be careful that the woodruf key on the shaft doesn't fall into the alternator, or under the work bench, or, well you get the idea. And remember to reinstall it when re-mounting the fan on the shaft. Getting the key to stay in place when installing fan can be a PIA, but if it is not located correctly the fan will not slide onto the shaft easily.
Good Luck Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic |
Thx got it...-chris
My fan is always hard to
