911crazy's Avatar
20/21 cams
Am I right in saying that 20/21 cams will work with stock euro 3.2 pistons? Thanks Craig
Old 06-19-2007, 12:11 PM
Mad Mike's Avatar
Craig,
I has 20/21 web cams in my Euro SC with a 3.2 short stroke. Worked fine. I had J & E pistons, not stock.
"Special performance grind for 911SC/ Carrera/964 engines. Works with stock injection." From webcamshafts.com
Mike
Old 06-19-2007, 01:15 PM
DYB DYB is offline
anyone able to answer the original question ?
ie are ROW 3.2 10.3:1 compression pistons compatable with 20/21 cams without any machine work ?
88 carrera
Old 06-20-2007, 08:29 PM
Jeff Alton's Avatar
Yes, they should work fine. This is a pretty mild cam.
If you need more info, you could alway email or phone WEBCAM and get their opinion, seeing how they are the grinder........
Cheers
www.turn3autosport.com
Old 06-20-2007, 08:38 PM
seems like there's a lot of us wondering.......especially here down under!
cheers,
Phil
84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies.
Old 06-20-2007, 10:03 PM
