changing valve cover gaskets
Ok... I'm exposing my lack of knowledge on 911's but I gotta start somewhere. Do I have to drain the oil to change the lower gaskets of the valve covers? Do I just drain the engine or the tank as well? Any little tricks you guys do when performing a gasket change? Put them on dry, RTV, etc? Thanks
-Jim
75 911S targa SOLD
67 912 SOLD
1984 911 Carrera
Old 06-27-2007, 04:20 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
No drain...dry gaskets...
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 06-27-2007, 04:35 AM
durn for'ner
livi's Avatar
Some members seem to use a procedure where they jack up one side at the time, letting the oil in the engine flow over to the other side. Personally I do these maneuvers while I do an oil change so I can work completely 'dry'.
The actual change of gaskets is straight forward. Just make sure you clean the surface thoroughly from old gasket material.
Markus
Resident Fluffer
Carrera '85
Old 06-27-2007, 04:43 AM
emac's Avatar
Jim
DO NOT pull the lower valve cover off unless you drain the system, and or jack the car up on one side. If you do you will be swimming in about six qts. of oil. Bet you wonder how I know?
Ernie 81 SC
Old 06-27-2007, 05:13 AM
Evolved
Mo_Gearhead's Avatar
Chatas,
The "search" function on this board is priceless. Do a search on valve covers and read.
You will find that you should: clean the surfaces WELL of old gasket material. Apply new gaskets DRY. Use new Nylock nuts and washers. Check valve covers for flatness. (They become warped by previous owners over-tightening them.) Use LOW torque value when reinstalling. Good luck.
Don't fear the reaper.
Old 06-27-2007, 06:26 AM
Thanks to everyone who responded! Mo_Gearhead, you are correct, the search is awesome. I have been reading for the last couple of weeks. Great information! Thanks
-Jim
75 911S targa SOLD
67 912 SOLD
1984 911 Carrera
Old 06-27-2007, 04:10 PM
disband
juanbenae's Avatar
i have recently been told by a very good source to spray the surface of the head & covers with WD-40 before reinstall. it will keep them from stick during the next removal.
Old 06-27-2007, 04:14 PM
Make Bruins Great Again
Por_sha911's Avatar
When you are cleaning the old gasket off, be careful not to scratch the cover where it meets the gasket. It could cause leakage issues.
Joe
Old 06-27-2007, 07:59 PM
