Engine Discussion: Various definitions of HP, 2.7 vs. 3.2?
Hello Pelicans,
I was reading that terrific series of articles in Classic Motorsports Magazine that talks about the 1973 Carrera RS. The article says the Carrera RS had a 2.7 liter engine that produced 200 SAE net horsepower.
First discussion topic: What do the various ratings of horsepower mean? I have seen: SAE, DIN, RWHP, BHP and a few others.
Second discussion topic: How is it that the 2.7 engine produces 200hp, and the 3.2 liter engine produces 207 hp? The 2.7 was said to be a compression ratio of 8.5.1 and the 3.2 is 9.5.1, and the Euro model 3.2 was 10.?.1 producing 231hp. Why doesn't the 3.2 Carrera, bigger motor with higher compression ratio put out much more than the 2.7?
Black 1985 Carrera ~ Whale Tail - Gone but not forgotten
2013 Boxster - Wifey Car
1969 Karmann Ghia - Next in line for restoration
"Driving in its most beautiful form"
Old 06-21-2007, 11:01 AM
PRO Motorsports
Tyson Schmidt's Avatar
Camshaft timing and overlap, rsulting in very different torque curves for one.
The RS has S cams which make peak power at higher revs.
The area under the curve greatly favors the 3.2.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 06-21-2007, 11:52 AM
randywebb's Avatar
SAE net is ~~= to DIN hp.
SAE gross is a lot higher.
The difference lies primarily in the test conditions - what accessories are required to be connected to the motor when yo measure hp.
RW hp = hp measured at the rear wheels. This will be lower b/c of frictional losses in the gearbox, etc. and tire squirm and so forth. To compare engines, you need an engine dyno not a so-called "road" dyno. The latter measure RW hp.
These are not really 'discussion' topics. They are merely definitions.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 06-21-2007, 01:39 PM
