She/Her
BeauBlues's Avatar
G50 Throw out Bearing Shims?
The T/O bearing came with 2 shims, but for the life of me I cant get the circlip to fit with both shims. And yes, I am putting weight on the pressure plate, in fact, I am putting my entire overweight self on that sucker. Now to my point. I took one shim out and the bearing fit like a dream, all locked in place and even more importantly there is no play in the bearing. It feels like it is firmly in place. Is this OK?
Gwyneth *she/her
1995 993 Guards Red
1984 911 Targa with a G50 (RIP)
Old 05-21-2007, 02:44 PM
Make Bruins Great Again
Por_sha911's Avatar
Exclamation
Help! I'm having the same problem. Do I have to use both shims? The circlip snapped in beautifully with one shim in there.
Joe
Old 06-20-2007, 06:25 PM
buttjoint's Avatar
No You have to have them both, That why ya have the shims. ya put 2 shims, the spring washer insert it into the front of the pp and then install the trush washer and then the locking ring.
Old 06-20-2007, 07:17 PM
Por_sha911's Avatar
OK so how do I get the circlip out to put the second washer in there?
Joe
Old 06-20-2007, 07:33 PM
buttjoint's Avatar
I scaned the bentley manuel. Send me your email and I will foward it to you
Old 06-20-2007, 07:39 PM
buttjoint's Avatar
Take the locking ring out and start all over. No big deal btdt
Old 06-20-2007, 07:51 PM
Por_sha911's Avatar
OK, we'll figure it out. Thanks.
New Question: do I grease the TO bearing or just the guide tube and release fork? I'm using Wurth CU 800 hi temp/hi pressure grease.
Joe
Old 06-20-2007, 08:41 PM
evill's Avatar
You need both shims. You need a press to compress the spring washer enough to get the circlip into the groove.
My brother inlaw an I just did this the other weekend without a press. We put the outside surface of the throwout bearing on top of a jackstand, my brother inlaw, stood on the edges of the pressure plate while holding onto the garage door rail for support. While he was pressing down on the pressure plate with his feet, I was able to engage the circlip.
Ed
Basically, I'm One Giant Train Wreck.
http://community.webshots.com/user/evill914
Por_sha911's Avatar
evil & butt (boy that's weird): thanks. I took it down to the local machine shop. Ten minutes on the press and one bag of donuts later its ready to go.
Joe
Old 06-21-2007, 10:27 AM
She/Her
BeauBlues's Avatar
I got to thinking about this. Why does there have to be 2 shims? The shims serve no load purpose, thats the thrust washer and snap ring's job. I'm sure someone here has put on one shim and had no problems.
Gwyneth *she/her
1995 993 Guards Red
Old 06-21-2007, 11:10 AM
evill's Avatar
The shims keep the throw out bearing tight against the spring fingers on the pressure plate. Without both shims, the outer housing of the throwout bearing will rotate on the spring fingers causing noise and wear.
Ed
Old 06-21-2007, 12:03 PM
buttjoint's Avatar
I was told not to grease anything. Picks up dust and so forth. Should be a ton of stuff in the search index under g50 upgrade.
Old 06-21-2007, 03:48 PM
