-   -   Can I use an MSD and a Crane XR700 together? (http://forums.pelicanparts.com/porsche-911-technical-forum/353293-can-i-use-msd-crane-xr700-together.html)
Kevins911 06-21-2007 05:15 PM
Like the title says:) I just installed a '77 2.7L engine in my car, but the dizzy has no points in it. I allready have an MSD 6AL and MSD coil installed, can I use my Crane XR700 with that?
Kevin
jpnovak 06-21-2007 06:48 PM
You don't even need the XR700 package, just the optical trigger. Feed the white wire from the distributor into the MSD as a points input. Will work with no problem.
Kevins911 06-21-2007 08:56 PM
perfect, I'll give that a try. Thank you.
911pcars 06-22-2007 12:52 AM
Not wanting to clutter up my garage with more stuff, I left the XR-7 box in the car and installed a Crane Hi6S on top of everything. I know, not the KISS principle, but it ain't broke, so I ain't fixing it...... yet.
The connections to an MSD box should be similar.
Sherwood
jluetjen 06-22-2007 10:42 AM
I've got that in my car. I posted a schematic a couple of years ago. If you do a search on my posts and "ignition" you'll most likely find it pretty quickly.
911pcars 06-22-2007 04:39 PM
Here's my Hi6S with a XR-700. Solo XR700 since 1998. Combo still works fine after 3+ years. Crane Hi6S was mounted this way to access the rpm limiter controls on one end.
http://forums.pelicanparts.com/uploa...1182555274.jpg
Sherwood
jluetjen 06-23-2007 06:17 AM
Here's my schematic...
http://forums.pelicanparts.com/uploads/MSD.jpg
Kevins911 06-23-2007 07:41 PM
Again, thanks for the replies, very helpfull info. But the engine is out of the car again, it seems to be locked up, it will turn almost a full rotation and stop and it will turn back and stop. Good enough reason for me to pull it apart and throw in my RS(or better) pistons and some S cams :D
Kevin
