Is the car damaged after driving with the parking brake on?
Wife drove the car to work on Monday and when she arrived realized that the parking brake had not been full disengaged. I could swear now that the brake now pulls up higher than it used to but that could be imagination.
Wife noted she did not feel any drag as she drove the car but has only driven it once. I drove it today and noticed nothing. thanks for any input.
87 911 coupe "Katy" Summer Yellow Linen Mahogany interior 04 Pilot "The Pilot" |
If the emergency brake still works, I wouldn't worry about it would be my guess. Not sure about the 87 but my 77 uses a drum brake for emergency seperate from the disc.
I think no worries.
77 Carrera 3.0 |
You might have to readjust your parking brake. If it was on it would have worn down the shoes a little but no harm done.
Scott
1988 Porsche 944 Turbo S 70,000 1987 Porsche 911 107k (sold) 1982 Mercedes 240D 4-Speed (mileage unknown) 1998 Mercedes E300 Turbodiesel 147,000 (sold) 1985 Mercedes 300D 227,000 (sold) |
Designer King
If the brake handle was raised only slightly, say 1 "click", then there probably was minimal wear, if any. If it was raised more, then all you probably did was add a little wear to the friction material. I wouldn't worry about it.
Does the brake feel fully engaged by the 3rd click?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Most likely no damage save some excessive wear on the brake shoes for the e-brake. If she did not have to slip the clutch to prevent stalling the car because of the drag of the brakes, then you got away with mimimal consequences. Higher pulling of the brake handle is probably real, given the tension on the shoes during the drive. Don't tell her though--just say she now owes you big time.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
I will have to check which click engages the brake now but thanks for the reassurances. I had told her the clutch was stiff but....
UFLYICU
Oh, it's definitely damaged. You'll have to spend big money to repair HER huge mistake. I think you can milk this one...
_______________________ Racer Rix Spec911 #5 prc-racing.com |
I'm assuming she will be driving the Pilot from now on??
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD ![]() 04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP ![]() http://www.eurocompulsion.net |
She actually drives an Accord but I had her take the 911 so I could change the oil in the Pilot and Accord. Next time I will do that on a weekend.
I hope she isn't reading this thread
Carsten AKA Sapporo Guy ![]() 1982 SC -- US import it seems ... weeeeeeeeeeeeeeeeeeeee
The excessive heat generated from that mistake is going to require a replacement of the rear tires. Don't want them blowing out with no warning, right? She's lucky they didn't blowout while she was driving! She really dodged a bullet there. Well, off to the tire store.
Joe 85 Carrera 64 Honda Dream - for sale 71 Hodaka Super Rat - keeper |
I was thinking something like the unepected drag malfunctioned the 20 year old computer and I need to replace it with a Steve Wong chip.
I think there may be some exhaust damage as well. May need to replace it completly
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
Gon fix it with me hammer
if fully engaged, with good ebrake pads... the car wouldn't have driven well... so me things it was probably not engaged to well, and if it was, you needed new ebrake pads anyway...
inside of the drum , would make plenty noise if that was metal on metal... you'de know
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
I did that a while ago myself. The warning light cluster is not working at the moment so off I went with the e-brake engaged.
About a mile down the road I noticed a bit of vibration so I stopped. Could not see anything wrong so off I go again. Vibration still there...then I see it. The e-brake lever is still up. Dang! Released the handle and away goes the vibration. Must have gotten those shoes and drums pretty hot to have a vibration. Now I always do a mental check and release brake first after entering car. That and I pull it up a bit harder so car really drags on start off so I know somethings still engaged! That and I really need to replace that warning light cluster. Its not like I don't have it...I've got a new unit in the box just waiting to be swapped out. Good to know I'm not the only one who has done that! David
'89 3.2 Carrera Coupe-Silver Anniversary-sold '06 GTI/DSG |
"Honey, I just don't feel safe driving the car the way it is. While we're in there, we might as well upgrade the brakes."
Sergio The GT Lid Whisperer PCA 42yrs - National DE Instructor / Ex-RGruppe #197 '19 718 Cayman S (9th Porsche/1st with PDK) '14 Subaru Forester XT (Porsche support vehicle) |
AKA SportsCarFan
I have driven manual-transmission cars almost exclusively since 1977. Both my 911 & my daily-driver are manuals. But for some reason, I have occasionally left the parking brake on in the 911.
I don't think I have ever done it in another car. It's only happened 4-5 times in the 6 years I have owned it. For some reason, I don't seem to see that the brake is on, or that the e-brake light is on. Embarrassing to admit....
Doug Miller 1988 Guards Red Carrera |
Senior Member
BTDT. You probably wore some lining off your e-brake shoes. E-brake shoes are sometimes surprisingly expensive. If you replace them and can't get a decent price on replacements, have your existing shoes re-lined at a brake shop.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
ooo....in order to feel better, ask for corndogs and beer for dinner. to be eaten in front of the television watching UFC, of course.
(unless "wife" is secret code for "my dumbarse self )
poof! gone Last edited by vash; 06-22-2007 at 10:20 AM.. |
