I went to replace my fuel check valve today and did not see one on the fuel pump! Am I looking in the wrong spot or does this car have one?
I thought I would post a picture of what I am talking about...sorry for the blurry photo.http://forums.pelicanparts.com/uploa...1183944504.jpg
According to PET, the check valve isn't used on the SC, only Carrera.
Mark,
I assumed it would be since everyone says you may need to replace it and it shows the check valve on Pelican's part diagrams...HMMMM |
At this point you really need to get a set of gauges on there to determine where the failure is. The pump is expensive, however worth it if the internal valve has failed. |
Scott,
Thank you Sir for the sound advice...I will invest is a set of gauges. Would you happen to know what the small spring is inside the 17mm nut? When I removed the 17mm nut holding the fuel line to the pump, inside of it was a very small spring wedge sidway in the nut. |
Just thought I would post a final note on this. I did replace the check valve along with fuel pump and have absolutely no issues with starting. It actually starts better that it ever has.
| All times are GMT -8. The time now is 10:45 AM. |
