Zenith Cleaning
I finally go around to pulling the carbs off my '70 911T last weekend. I found two totally plugged main jets and all of the acceleerator pump jets plugged, The car sat for a few years before I got it, so everything seems to be gunked up.
What do you guys use to unplug and clean these carbs?
David Nolen
1970 911T
Old 05-13-2008, 06:17 PM
LakeCleElum's Avatar
Doing a set myself right now. I put all the jets in a one gallon can of Carb cleaner. For the passages, I squirt in carb cleaner and blow with compressed air.
That usually does it on most carbs I do. On these Zeniths, the Accel pump passages/injectors are still blocked. Will the tip of the injector pull straight up from the top of the carb? Looks like it should, but I don't want to force it...
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 07-07-2008, 10:16 PM
