How to power alarm
My car came with an aftermarket alarm. Typically how do these alarms get their power. Yes, I know the battery...but where do they run the wire. Is it as simple as running a wire to the battery or is it done in a more round about way. Thanks in advance.
Old 06-25-2007, 07:23 AM
myrddin's Avatar
what year is your car... I think I have a diagram of sorts.... The alarm is most likely tied into the main harness under the dash... you will have 1 hot wire and one ignition wire... amongst others....
Let me know I’ll post the diagram if I have it for your car.
looking...
Old 06-25-2007, 08:09 AM
Senior??? Oh very well
fly4val's Avatar
I have an '88 Carrera coupe, pls provide for mine if you have it, thanks!
Old 06-25-2007, 08:31 AM
I have an 88 Turbo Cab. Just a reminder, I'm not talking about the factory alarm. I'm talking about powering an aftermarket alarm. Thanks again.
Old 06-25-2007, 09:58 AM
myrddin's Avatar
Here is what I have for an 88 911 (I guess turo is the same)... It lost all the tables so if you like pm me with your addy and Ill email you the page I have.
WIRING INFORMATION: 1988 Porsche 911 Carerra
WIRE WIRE COLOR WIRE LOCATION
12V CONSTANT WIRE RED Ignition Harness
STARTER WIRE YELLOW Ignition Harness
IGNITION WIRE BLACK Ignition Harness
POWER DOOR LOCK (-) BROWN/BLUE Harness From Driver’s Door Near Driver’s
Strut Tower
POWER DOOR UNLOCK (-) BROWN/GREEN Harness From Driver’s Door Near Driver’s
Strut Tower
PARKING LIGHTS (+) GRAY/RED (right) GRAY/BLK (left) At Headlight Switch And At Fuse Box
HEADLIGHTS (+) YELLOW (LOW BEAMS) At Headlight Switch And At Fuse Box
DOOR TRIGGER (-) BROWN/WHITE Harness By Passenger Strut Tower
FACTRY ALARM ARM Some vehicles armed and disarmed with a
separate alarm key switch located on end of
driver's door. Other vehicles arm with lock
and disarm with unlock.
Factory anti-theft unit tucked behind the
heater ducting under cowling under hood.
Major disassembly required to access the
anti-theft unit.
FACTRY ALARM DISARM Some vehicles armed and disarmed with a
anti-theft unit.
TACHOMETER WIRE GREEN or BROWN At Ignition Coil
BRAKE WIRE (+) BLACK/RED At Brake Pedal Switch
HORN TRIGGER (-) BROWN/WHITE Harness At Steering Column
LEFT FRONT WINDOW UP BLUE At Window Switch
LEFT FRONT WINDOW DOWN BLUE/BLACK At Window Switch
RIGHT FRONT WINDOW UP RED/WHITE At Window Switch
RIGHT FRONT WINDOW DOWN RED/BLACK At Window Switch
looking...
Old 06-25-2007, 04:07 PM
