Oh So Fast
turbosporsche's Avatar
911 turbo wont start
I have an 87 911 turbo. Just pulled the engine to do a new tranny. While it was out i washed the engine and replaces seal, gaskets bla bla bla. I reinstalled everything and now she wont start. I have spark and i have fuel at the intake injectors. Im so confused. any help would be apprea.
Old 06-21-2009, 01:33 PM
someone else here had good fuel and spark... but plug wires were hooked up in the wrong order. Any chance its that??
Don't Lift... Don't Lift... Don't Lift
'75 Targa in "Arrest Me" Red, 3.0SC ('79) engine, Bilsteins, Turbo Tie-rods, SSIs into 2-1 M&K muffler... and looking for my next upgrade.
Old 06-21-2009, 02:21 PM
Oh So Fast
yes i double checked that.
Old 06-21-2009, 02:31 PM
over boost cut-off relay tipped or out of it's socket? white wire off the over-boost switch? delayed ignition cut-off relay dead? do you have power to the ignition unit at the red wire? (it should whine if you do, unless it's dead). do the fuel pumps work? (see the first two questions).
206 637 4071
Old 06-21-2009, 02:54 PM
Oh So Fast
ill take a look at those. Its weird cause the car ran fine before the tranny was taken out. I just tryied to start it again someone said it might have gotten flooded so i waited a while. It turned over started then died.
this sucks
Old 06-21-2009, 03:07 PM
