Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
Build a compression tester?
I've got a leak down test kit that has all the hoses and such to attach to a head. I got me thinking, is there anything special about the gauge of a compression tester that I couldn't find a gauge of the proper range and make my own compression tester?
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 06-27-2007, 07:30 AM
Jon Merck's Avatar
John I have one you can use...
Jon
Old 06-27-2007, 07:38 AM
Slumlord
Porsche_monkey's Avatar
You need a gage, a spark plug adapter and a check valve that will hold the air. And a way to release the air.
And you can't put all that together any cheaper than they can in China. Go to Pep Boys and buy one.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 06-27-2007, 07:41 AM
Stahlwerks.com
jhelgesen's Avatar
I'll have to take you up on that Jon......
I have the spark plug adapter and a ton of fittings adapters and other goodies, may even have the gauge, plus I'm a member of the "why buy what I can build" club.
John Helgesen
Old 06-27-2007, 09:09 AM
Slumlord
If you really want to build it:
You can use a tire valve as the check valve. Just slide a rubber sleeve on the OD and adapt it a gauge. Push it into the hole and voila, you have a peak-hold pressure gage.
You just need to reach inside it to push the valve stem and release the trapped air.
84 Cab - sold!
Old 06-27-2007, 09:13 AM
