rw7810's Avatar
Fluid in front struts
When I changed from Boge to Koni front inserts years ago, I found fluid in the bottom of the front struts. I later read that antifreeze was often put in there for heat dissipation. Do people still do that ??
Robert Williams
70' 911T
Old 06-27-2007, 06:51 AM
People put motor oil in there. I did it because it also made a very nice tight fit. I don't know if its necessary though.
Old 06-27-2007, 07:06 AM
aj88cab's Avatar
You will get mixed opinions on this. The factory Boge struts used the strut housing as the "shock tube". The fluid you found was the hydraulic oil that provides the shock dampening. Some folks like to leave some of the oil in there for heat dissapation. When I installed my Bilstein inserts I called the factory and they said it was not needed. I assume the same would apply to the Koni inserts. I have never heard of using anti-freeze though.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 06-27-2007, 07:12 AM
cycling has-been
bkreigsr's Avatar
I'm pretty sure the instructions that came with the old, full-hydraulic Konis and the factory manuals both say to add anti-freeze to prevent corrosion and help dissipate heat.
Might be just superstition, but I've always done it on the long nose.
Bill K
(also, Bilstein never made a full hydraulic insert)
Old 06-27-2007, 12:04 PM
