Wildman Emeritus
?'s For A/C Upgraders
I am thinking about system upgrades on my 80 SC. There seem to be many options at hand and before I go too $$ crazy for minimal results, I would like some feedback on the upgrades others have done.
I am leaning toward the Rennaire system from our host at $1200 rather than doing a piecemeal thing with compressor, Pro cooler and a new hose or two or a fender condensor. How easy is the installation of the Rennaire and what have the results been? I have been thru several searched threads but want feed back somewhat more recent than these. Can I get similar or better results from a different approach?
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
Mike,
I haven't completed an AC upgrade , yet, but I am in the same boat. I went ahead and ordered the Rennaire system. The determining factor for system vs peicemeal seemed to be the fact that the evaporator has a relatively high failure rate. I will also be watching this thread, and good luck with your project.
Tom 88 Targa - Mostly stock except cat bypass, SW Chip. 06 Audi A4 2.0t Quattro 02 Saab 9-3, 06 VW Passat, 06 Chevy Cobalt |
Bump
Un-Registered User
I've got a Kuehl system in my 88 targa. (Griffiths Tech). It was already installed when I bought the car. I have an invoice for $2506 just for the parts. It blows 45deg at idle and 38 deg at cruise speed. Works pretty good, but I'd rather have the top off.
Don 1988 Targa |
I installed Rennaire's system 2 last summer with 134a in my '86. Since I'm in Arizona working AC is pretty much essential in a daily driver. The OE nippondenso condensor was leaking around the shaft seal and throwing lube all over the place so I had a choice of trying to rebuild the compressor and stick with R12 hoping the remainder of the system would hold up or bite the bullet and install new & improved. I read as many AC posts as I could find and learned - thanks to Jim Sims & Kuehl that the reason the stock AC system didn't work well was that it was underdesigned primarily due lack of condensor capacity. With that in mind I ordered the Rennaire System with the serpentine front condensor, evaporator and procooler - which effectively acts as an additional condensor. The only thing I kept was the decklid condensor. The installation wasn't all that difficult, the kit instructions were good, and Ron was very helpful, but it did take time. It took me a little over 2 weeks off & on. The hardest part was threading the AC hoses to the front condensor because its a pretty tight space & you can't really see very well.
Last week with temps up to 107, I was getting mid 40's out of the vents. When it's only in the 90's I have to turn the fan and temp knob down or it's too cold.
1986 Carrera Coupe 1999 Chevy Tahoe 1987 Chevy Blazer 1955 Chevy Apache 3100 Pickup "A little knowledge is a dangerous thing" |
