P_O_R_S_C_H_E's Avatar
Porsche Crest 1987 911 Carrera 3.2 cold start blues...help!
Hi Guys,
First time posting here, I have a problem with my 1987 Porsche 911/993 conversion. I am running a 3.2 Carrera motor 47,000, new high pressure fuel hose, tune-up, plugs, distributor, battery, spark plugs, timing, oil seals, relays, etc. my car runs like a top, great idle and just flat out purrs...except on cold morning's, I can't get her to crank over!!! Early afternoon's and early evenings are just fine! Could this be some sort of 3.2 cold start issue, and if so what???
Old 12-17-2007, 10:17 AM
DonMo's Avatar
Send a message via AIM to DonMo Send a message via Yahoo to DonMo
No cold start valve or warm up regulator on 3.2's. How long before the idle stabilizes? Does it hunt or just run rough?
DonMo
1984 911 Carrera Targa
3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip
Columbia, SC
"Go Hokies"
Old 12-17-2007, 11:00 AM
Hi DonMo,
When it finally starts it idles fine, kicks right over! This of course if it's warm. It doesn't hunt or run rough, the idle is steady. When it finally starts, it purrs...
Old 12-17-2007, 07:03 PM
Jascha's Avatar
Welcome to the List.
The first thing you might want to consider is replacing / updating the cylinder head temperature sensor to a two wire type...
You might want to do the proverbial search (this is a common and much lamented problem)
1995 993 ('Under my Care')
1989 911 ('Go Pitt')
1996 993 ('Go Navy')
1984 911 ('Go Pelican')
Old 12-17-2007, 07:18 PM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
definitely check your cylinder head temp sensor. that helped with my cold starts
also think about getting your injectors really cleaned. that will help too
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 12-17-2007, 07:30 PM
DonMo's Avatar
I would do the CHT also, do a search on CHT and BMW and 3.2. There is a BMW part that is the same as the Porsche for much less the cost.
DonMo
Columbia, SC
"Go Hokies"
Old 12-18-2007, 03:11 AM
Jascha's Avatar
A little 'search help' will get you going here:
Guest Technical Article: Cylinder Head Temperature Sensor - Upgrade
http://www.pelicanparts.com/techarticles/911_cyl_head_temp_sensor/911_cyl_head_temp_sensor.htm
A thread with pictures (Head Temperature Sensor Replacement) :
Old 12-18-2007, 06:32 AM
I'd check the battery/alt before anything else
Old 12-18-2007, 10:39 AM
