Is 30 degrees total advance for 82SC safe?
US SC. Runs really well, I can't hear any pinging. Was only reaching 20 degrees BFTDC before I advanced. Idle mixture is set to the rich side using the Souk method. Idle is solid at 900. I do not want to risk engine damage for just a small gain in power.
Old 09-22-2007, 12:45 PM
Wer bremst verliert
JohnJL's Avatar
I believe you are good up to around 32-33 degrees at around 4000.
Is your distributor original? Have you refurbed it and checked all the internals? I dont recall if 82 had mechanical advnace weights but ifyou werent getting total advance they could be sticking.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 09-22-2007, 02:17 PM
I could see the timing advance as the RPM increased, so I think the dizzy is working properly. I can't say when it stopped advancing but it was right at 30 degrees BFTDC at 6k RPM.
Old 09-22-2007, 02:36 PM
What octane fuel do you use??????
Thats what REALLY determines what values you will time your car to,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-22-2007, 04:42 PM
Steve,
For a stock 82SC what do you consider the max safe advance when using regular (87), mid-grade (91), and premium (93)? Might as well throw in 100 octane too.
Thanks,
Mac
Old 09-22-2007, 05:32 PM
Originally Posted by 911Mac View Post
Steve,
Thanks,
Mac
Mac:
I never, ever use, nor recommend anything but (92 in OR) 93 in these cars for street use so I would time the car to factory specs. Mixing 100 is only for DE use in hot weather.
You can read more on this at http://www.rennsportsystems.com/2a.html.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 09-22-2007, 06:21 PM
91 is the highest grade available in my area, I use it exclusively.
Old 09-22-2007, 07:07 PM
