aj88cab's Avatar
Oil Line Damage - Don't let this happen to you!
A couple of weeks ago I noticed that the oil line bracket shown in the first photo was broken. With a DE in two days I rigged the replacement shown.
Today I was replacing the leaking timing chain cover gaskets and tensioner o-ring and noticed this damage to the oil line from rubbing on the heat exchanger cross over tube (see second photo for close-up). This is the hard line that goes from the driver side of the engine to rubber/hard line on the passenger side.
I also noticed that the bracket I made was a little longer than the factory backet and may have contributed to the damage.
I am not one to take chances with the oil lines and will probably replace, but I was wondering if I could even consider filling the damage with J-B Weld. (flame suit on).
Regardless of the answer, if anyone finds this bracket broken, don't put off repairing it. It would be a shame to loose your oil (and possibly the engine) because of a broken $2.50 bracket.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 06-30-2007, 02:23 PM
