-   -   engine will only idle (http://forums.pelicanparts.com/porsche-911-technical-forum/354874-engine-will-only-idle.html)
jtparr 06-30-2007 02:57 PM
hi from a wet and windy UK
the restoration of my 75 model year Euro spec 2.7 Carrera was all going to plan until we fired up the engine after having had it laid up for over 2 years
Its been backdated to an RS Touring look body, in gleaming shiny black,
the restoration is on the DDK site if you'd like to have a look
http://www.ddk-online.com/phpBB2/viewtopic.php?t=12123
in simple terms it will only idle and no more, and its a hell of a mystery
over the last 2 weeks I have generally checked
fuel pressure
connections of all fuel lines
fuel filter
timing
MFI pump rack movement
MFI pump timing
delivery of petrol through the injector pipes
and now have absolutely no idea what to do next...all very depressing
there's a long post on the DDK site
http://www.ddk-online.com/phpBB2/viewtopic.php?t=15535&postdays=0&postorder=asc&sta rt=0
just wondered if this struck a chord with any of you folks, it must be something either fundamental or just plain simple, which I cannot see
help please
thanks a lot
Jonathan
unclebilly 07-01-2007 06:45 AM
Is your throttle linkage connected?
Purkinjefibre 07-01-2007 07:19 AM
2.7 trouble
J, read through your DDK story. You say before the resto that it was running OK- a bit vague, was it really running well or not? Anyway it sounds like fuel pressure to me also. There is only one thing that sounds troubling, POR15 treatment of CIS petrol (gas) tanks can cause narrowing and or blockage of the fuel pickup lines that leave the gas tank. I don't know if anyone has reported similar difficulties with MFI tanks. Simple test would be to feed fuel to your MFI fuel pump from an unrestricted source, e.g. a fresh fuel line running to a fuel can (fire extinguishers handy, as always).
Good luck
jtparr 07-01-2007 12:25 PM
hi Purkinjefibre
I'd go with whtat you say except that I have managed to easily get the 1 litre of fuel delivery in 30 seconds in a test run
also as of today took one of the injectors off (as it enters the engine block end) and put the end into a small jar
filled about 1cc in 10-15 seconds and came out in a fine mist, so I think petrol delivery is OK
I did renovate the tank but flushed it out with about half a litre before I connected up the outlets, so I'm fairly sure its clean......
thanks for the reply
jonathan
DanielDudley 07-01-2007 04:02 PM
Mouse nest in exhaust ?
bigchillcar 07-01-2007 07:32 PM
timing? everything on the list is fuel-related. what about ignition concerns? granted my early car background only goes back to 1974 and cis..
JP911 07-02-2007 05:23 PM
I'm with Ryan. Start going through the ignition, starting with a timing check. It sounds like you're not getting any advance.
bigchillcar 07-02-2007 06:51 PM
yep.
jtparr 07-03-2007 02:17 AM
thanks
have done a simple timing check, but will do it again this weekend a bit more carefully
jonathan
bigchillcar 07-03-2007 07:08 AM
check both static and dynamic timing.
svandamme 07-03-2007 03:11 PM
plugged vacuum ports on the throttle bodies or vacuum lines perhaps?
94teener 07-03-2007 03:26 PM
I had a similar problem with my '77 911S - not exactly the same symptoms but it could well be the cause of your problem - check the vacuum hose leading from the brake servo to the engine. The hose is well hidden from view. My car ran like ****e for about 6 months and I went absolutely mad checking everything to no avail. I finally took it to my mech. and he diagnosed it quickly as that hose had split - $5 hose and now runs perfect.
Good luck!
