Jeff Alton's Avatar
Finally got the hood mounted!
So, finally go the hood mounted. It is a "flat", hood from Rennspeed, that I believe is made by AIR. It took considerable trimming of the the "lip" area thickness to fit.
I elected to use pins instead of the hinges and latch. I used aluminum pins from OMP. The hood is easy to remove and install as it weighs around 12lbs. Just pull the pins and lift it off.
It was a bit of a pain is the A$$ to install as I had to weld brackets in for the upper pins by the windshield, and getting the pins lined up in general is a bit of work. Overall I am happy with it.
I will fair it at a later date, motor fire up and tunning is taking a front seat. I will paint the whole car in the fall/winter this year.
As a side note, I have another set or pins to hold the ductail down. It has "R" hinges so the pins will work great.
Here are some pics.....
Cheers
jeff@turn3autosport.com
997 S 4.0, Cayman S 3.8, Boxster 2.7, Boxster S race car, 996, 955 Cayenne TT, 958 Cayenne TT
Old 06-30-2007, 09:03 PM
Jeff - this looks very nice. Looks like the gaps next to the fenders look real good so when you get it painted I think you will be very happy with the result.
Regards-
Thomas Owen
1972 911T
Old 07-01-2007, 03:05 AM
Oh Haha's Avatar
What do you gain going to this "flat" hood? Obviously, light weigt.
Pacific Blue
Wayne
Old 07-01-2007, 04:22 AM
Erik Mckenna's Avatar
Off the top of my head I would think the flat hood would just clean the air flow up.. more areodynamic. I would guess.
" The reason the Irish are always fightin each other is that there are no other worthy opponents"
Old 07-01-2007, 05:55 AM
Jeff Alton's Avatar
I think the aero advantaage would be lost my use of hood pins, but I think aero is the idea behind it. I don't have any of the stock HVAC plumbing so the fresh air vent is not used on my car, so the flat hood made sense to me.
The gaps are a little oversize, but no worse than my MA Shaw ducktial. Car will be primarily a DE car with occasional street use, so I am not too worried about the slightly larger gaps.
Cheers
Old 07-01-2007, 06:19 AM
Jeff, You decided to use pins for upper section but can hood accomodate standard hinges? I'm in the market for figerglass hood.
It looks real good to me.
Old 07-01-2007, 07:05 AM
BlueSideUp's Avatar
Send a message via AIM to BlueSideUp
Jeff-
Is the MA Shaw duck lighter or heavier than your OE deck lid? Was there a lot of work involved with installing the duck?
Nice work getting the gaps even....I saw an M3 with a composite hood last week and you could drive a truck through the driver's side gap while the passenger's side was really tight.
-Jess
Old 07-01-2007, 08:32 AM
Jeff Alton's Avatar
Ed, the hood has inserts in it to bolt onto the hinges, same goes from the front latch. You can't use hood shocks though with a glass hood (or at least you risk cracking it if you do) so I elected to just use the pins so I can take it off.
BlueSideUp, I changed the tail about 3 years ago...... My car had a carrera tail on it before so I did not compare it the weight of a factory steel lid. It is light though, my guess is a little lighter than a stock lid.....
I used wood shims in the gaps while I was lining it all up. Made it easier to set up the pin holes and placement. With the shims you can still move it forward and back to get that set without screwing it up side to side while you align it.
Cheers
Old 07-01-2007, 09:01 AM
randywebb's Avatar
"I think the aero advantaage would be lost my use of hood pins" -- not at all.
Beside the lower drag (see the 996, 997, Boxster & Cayman), you also lose a fair amt. of wt. See:
http://www.penaltykicker.com/911/data/
DisAdv's:
You get worse fit tho & worse ventilation plus losing that characteristic ID of the 'true' 911s.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 07-01-2007, 12:33 PM
