Zero Oil Pressure - any ideas??
I live in Belfast, Northern Ireland and I've just imported a 911 from sunny California.
It's a 1970 911 E Targa and it arrived on Saturday morning. The car has been sitting for 3 months during the shipping process and so when it arrived the battery was dead. I give it a good charge for a number of hours and when I started the car I realized the oil pressure guage did not move at all and was registering zero.
I switched the car off straight away as I was afraid to do any damage. I have tried the car again a few times with the same result. Apparently the car was fine before it left CA and the engine sounded fine in the short time it was running. This is my first Porsche and so I have no idea of how serious the problem may be - does anyone have any ideas or suggestions?
Paul
Old 05-21-2007, 02:11 PM
1st of all make sure it really has or does not have oil pressure, a mechanical gauge to test would be the best way. Once you have determined if you truly have oil pressure, you can move on from there.
1974 911 targa 2.7 (for the road)
1974 FJ40 Landcruiser (for no roads)
1995 Dodge V-10 HD2500 4x4 (to tow anything I want)
2005 Durango (wifes rig, I've driven it twice)
2000 Fisher Freedom 200 w Mercury 115 ELPTO (because the world is mostly water)
Old 05-21-2007, 02:14 PM
FenderGuy's Avatar
Might be the oil pressure sender needs to be replaced. My druck was stuck at 5, changed it out and now it works !!!
Frank
1980 SC Cab Conversion (sold)
1974 914 2.0 RIP rear ended
Looking for a 996 Silver Cab 2002-2004
Old 05-21-2007, 02:19 PM
boxster03's Avatar
no oil
Member #750 Early911S Registry
1970 911E
I know Where Jerry S. has his NYC Garage
Yadda Yadda Yadda
Old 05-21-2007, 03:36 PM
LakeCleElum's Avatar
Quick way to check: Loosen the large bolt on the banjo line that feeds he rockers (one located to the rear of each intake valve cover. Start the engine, if oil come pouring out (I bet it does), you have oil pressure.....Tighten the bolt quickly and troubleshoot from there as to why you have no reading....
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 05-21-2007, 03:39 PM
Let's try some old fashioned trouble shooting.
First we know if the wire to the oil pressure sending unit is disconnected the oil pressure gauge wil read max high.
We also know if that same wire is grounded the oil pressure gauge will read zero, maximum low.
So disconnect the wire to the sender and see what happens.
Now with an ohm meter, read the terminal of the sender to ground.
With the engine running the resistance should vary. Probably somewhere less than 10K ohms.
If the sender reads ground continously, bad sender.
If the sender reads ok and the meter goes up and down, Bad wire.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 05-21-2007, 05:05 PM
fanof911's Avatar
Hi
Sender problem.
Check it as exposed by tracer.
I doubt there is no oil nor oil pressure in your engine. It is not 3 months of travel that would have damaged the oil pump.
Fanof
911SC 83
132kmiles
Black, Turbo tail
Black leather interior
Old 05-22-2007, 12:52 AM
emac's Avatar
Hey guys
Dont want to be a wise a$$ but don't you think the first thing he should do is pull the dip stick out and see if there is any oil?? I would say that is the most easiest. Not saying it could be so low as to not show on the stick. Just my 2c.
Ernie 81 SC
Old 05-22-2007, 04:25 AM
fanof911's Avatar
Good point emac
Fanof
911SC 83
132kmiles
Black, Turbo tail
Old 05-22-2007, 04:28 AM
Hi
Thanks for the responses guys and a quick update - the oil level guage is reading half full (6 I think), and I checked the dipstick and it is showing about the same. The oil pressure guage is still not registering though.
I'm beginning to wish I had just stuck with the classis Mini coopers - everything is so much simpler (and cheaper)!!
Old 05-22-2007, 05:09 AM
fanof911's Avatar
Then it is the sender.
Not quite difficult to assess and to change and not much expensive, in France at least.
I have a tech article on it but in french, if you're able to read french I can send it. Let me know by PM.
Fanof
911SC 83
132kmiles
Black, Turbo tail
Old 05-22-2007, 05:48 AM
Friend of Warren
Fanof
Probably, but I'd sure as hell be checking to see if the oil pump is working first!
Kurt V
Old 05-22-2007, 06:02 AM
jabb's Avatar
I agree lets not Assume its the sender. Confirm it but doing the checks mentioned earlier in this post.
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Old 05-22-2007, 06:36 AM
Yes, while it is almost surely the sender/wiring, PLEASE AT THE VERY LEAST CRACK THE BANGO FITTING ON EITHER OIL LINE AND HAVE A BUDDY CRANK IT WITH THE COIL WIRE DISCONNECTED.
Once we are sure we have oil pressure do the sender tests 2.7Racer outlined.
Old 05-22-2007, 07:26 AM
PHP Code:
I'm having a problem with my oil pressure/temp guage not indicating. The temp guage is pegged to the top and pressure is peggen to the bottom. I did the above checks on the senders and they work just fine. I'm not the greatest with a volt meter but if someone can explain it I can do any checks. Anyone able to help or know what other problems I may have?
Old 07-02-2007, 02:03 PM
