-   -   A/C not working (http://forums.pelicanparts.com/porsche-911-technical-forum/355099-c-not-working.html)
Garrison 07-02-2007 06:36 AM
A/C not working
My climate control is not working in the car at all and I am wondering what might be wrong.
The rear defrost button lights up and the door lock button works, but the climate control knob for the fan, and A/C do not work.
I recently replaced the seats in the car with some aftermarket seats, and I did cut the wire that was connected to the drivers seat belt, but am assuming that this might not be the issue? or is?
Any ideas on where to start or what might have caused these 2 knobs to not work?
Thanks.
Garrison 07-02-2007 11:47 AM
any thoughts?
rick-l 07-02-2007 12:39 PM
To condense this down a little, the symptom is your AC blower does not work and the compressor does not come on???
Have you checked the fuse in the luggage compartment?
Garrison 07-02-2007 01:15 PM
The fan does not blow at all, whether cold or hot air.
The climate control does not work at all... the fan or the A/C.
dshepp806 07-02-2007 01:59 PM
fuses checked?
rick-l 07-02-2007 02:23 PM
The fuse that goes to the power seat also runs the AC in an 88.
I don't have the CC option but I didn't think it controlled the AC
Garrison 07-03-2007 08:22 AM
Haven't checked the fuses... but that is the next step. Also going to reconnect the wires that I cut as I think one of them is the ground for the climate control unit.
esample 07-03-2007 08:38 AM
Re: A/C not working
Thanks.
Whenever I troubleshoot, I always ask "what has changed or what have I done since XXX worked last? I would start back at the seat install.
-ernie
