Pingo's Avatar
Por-15
I have acid dipped my Targa tub and considering painting the clean tub with POR-15.
Anyone know how much POR-15 I am going to need?
Old 07-04-2007, 09:01 AM
DanielDudley's Avatar
I would consider having the whole car primed in self etching epoxy primer. This is as impermiable as POR 15 and it is what the pros use. I would not put POR on any surfaces but the underside and floor pan. You will also need to use ty-coat to put a finish over POR.
Old 07-04-2007, 09:28 AM
khamul02's Avatar
Isn't there an issue with UV exposure and POR 15? Not really sure just think I read that somewhere?
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 07-04-2007, 11:18 AM
+1 on what Daniel said. You will need quite a bit less than a quart to do the underside. You might also consider painting some of the suspension parts with it.
Marv Evans
'69 911E
Old 07-04-2007, 12:07 PM
POR stands for paint over rust. It really doesn't bond that well to clean metal. You could have just painted the tub without acid dipping it!
Old 07-04-2007, 01:07 PM
khamul02's Avatar
Acid dip is a plus!
No rust is better than some rust with por over
Tom Hutchinson
Old 07-04-2007, 01:27 PM
