Cornpanzer's Avatar
Horn wont stop blowing - 70 911
When I took my Momo wheel off and replaced it with an original wheel, my horn began blowing. I have switched between my round 912 horn button and the original butterfly. I have switched contacct pins. What else could be causing this? I finally had to remove the relay.
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/
1970 911S,
10 sec 67 Beetle (300 rear wheel HP)
RGruppe#252
Old 07-06-2007, 12:21 PM
Banned
gassy's Avatar
Send a message via ICQ to gassy Send a message via AIM to gassy Send a message via Yahoo to gassy Send a message via Skype™ to gassy
Same thing happened to me--haven't fixed it yet but about a year ago a thread was started by someone that put one of those rings from the cap of a gallon of milk under the butterfly and that solved it.
Old 07-06-2007, 12:29 PM
Friend of Warren
Either the two contact rings under the horn pad are touching or, like on my '86 you didn't tape off the second horn ground wire and it is touching inside the column. Not sure if your '70 had two ground wires. Don't even know why my '86 does.
Kurt V
Old 07-06-2007, 12:30 PM
Ayo Irpin, Ukraine!
70SATMan's Avatar
How's your rubber return spring?
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 07-06-2007, 12:36 PM
Cornpanzer's Avatar
Rubber cup is fine. Like I said, I have tried two caps, so I am a bit mystified
1970 911S,
RGruppe#252
Old 07-06-2007, 12:44 PM
Banned
gassy's Avatar
Here's the link--it was the cap not the ring...
Simple Horn Fix!
Old 07-06-2007, 02:39 PM
Cornpanzer's Avatar
Turned out to be the steering wheel itself. I got looking close and noticed that one of the mounting flanges for the horn button was ever so slightly tweaked out on one corner. This was just enough to contact the horn button and blow the horn.
Feels good to figure one out
1970 911S,
RGruppe#252
Old 07-06-2007, 02:57 PM
rexav8r's Avatar
I was going to say, maybe somebody was just in your way ????
Richard W.
Red '70 E, 2.2
White (w/ Red & Blue), '82SC, "Frankenstein" -a bit tweeked
Old 07-06-2007, 06:10 PM
FenderBender's Avatar
Warning!! Danger!!! Danger!!!
My son purchased a 1966 911 project car. I was over helping him get it running. He told me the horn went off for no reason and he had to unplug it? Ok what ever, lets get this thing fired up. Is what I was thinking.
While we had it running and both our heads under the hood. He looked up and said Holy Sh*# and went running to shut the car off. I looked up to see a cloud of smoke.
After the smoke cleared we discovered that he unplugged it at the horn. (and I did not think anything of it) The Hot wire grounded its self on the horn and burned up most of the wiring all the way up to the fuse box. Make sure you pull the relay and maybe the fuse untill you fix it.
It turned out the wire in the aftermarket steering wheel came off and grounded it self.
All I can say is Freak accident but be carefull.
Mike
'99 Isuzu VX, 2005 Audi A4 1.8T Quattro
'96 BMW 328ic
'73 911T Targa SOLD
www.flickr.com/photos/fenderbender813
Old 07-06-2007, 07:34 PM
