oil level and plugs
Hello everyone,
I know I have seen some general threads on these subjects, but I wanted to ask two specific questions about these: 1. My euro 3.2 stalls when I remove the oil cap to access the dipstick and check the oil level. How can I check it correctly? How can I prevent it from stalling? Do I have only the oil level gauge to go by? Is this good or bad that my engine stalls when the oil cap is removed? 2. I am thinking of putting some NGK copper plugs in for my euro 3.2. What is the correct plug and do I have to gap them? Do they make a 3 prong copper one? TIA, Scott
72 911 T Targa in Orient Red / Black - more like a 85 Euro RS IROC now - 85 Euro 3.2 with x-faktory EFI ITB + SSI + Dansk, 915 + Wevo, flares + IROC bumpers + duck tail, RS door panels, Corbeau LG1 microsuede seats, Speedware harness bar + drop links + Scroth DOT harnesses, adj Tarett sways, sport shocks, alloy trailing arms, Elephant Racing oil lines + spring plates + bushings, RSR Rota Foxes + Bridgestone S-04 PP, 2450 lbs Last edited by sbrown.nw; 06-18-2007 at 11:34 AM.. |
I'll take a stab:
1. what's your idle set at? when you remove the filler cap the idle will drop b/c the vacuum pressure is affected. 2. recommended plugs? Bosch WR7DC Spark Plug: http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_BAStun_pg1.htm#item0 Good luck, Jack
Warren Hall (Early S Man), 1950 - 2008 ------------------------------------ 2006 Tri D675 Scorched Yellow 2006 Ducati Sport Classic mono SOLD 1979 SCWDP #0020 Talbot Yellow SOLD |
i think you are missing (or it is skewed in the hose) part 10a. it is a restrictor. car will die without it, if you take the oil cap off.
poof! gone |
It was the regulator. Good catch and thanks again.
Scott
72 911 T Targa in Orient Red / Black - more like a 85 Euro RS IROC now - 85 Euro 3.2 with x-faktory EFI ITB + SSI + Dansk, 915 + Wevo, flares + IROC bumpers + duck tail, RS door panels, Corbeau LG1 microsuede seats, Speedware harness bar + drop links + Scroth DOT harnesses, adj Tarett sways, sport shocks, alloy trailing arms, Elephant Racing oil lines + spring plates + bushings, RSR Rota Foxes + Bridgestone S-04 PP, 2450 lbs |
Re: oil level and plugs
ps: Yes, make sure they are gapped correctly even if they are new. Last edited by KFC911; 07-06-2007 at 06:22 AM.. |
