drag racing the short bus
dd74's Avatar
Member: torn sway bar mount club...
Yet another item to R&R. Question is: what causes it?
1) Old mounts?
2) Stickier tires?
3) The planet Mercury in retrograde?
Remedy: factory mounts and reinforcements.
Who else has this happened to?
The Terror of Tiny Town
Old 07-05-2007, 01:17 PM
Crusty Conservative
silverc4s's Avatar
Combination of all three
Happened to me, driver's side only, on my targa with 235's on 7 x 16's
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 07-05-2007, 01:28 PM
wevo rear sway bar mount
my strap didn't fit correctly so i tweaked it. Then I found out the SC or Carrera strap is different than mine and a perfect fit.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-05-2007, 02:00 PM
greglepore's Avatar
Second Ronin-go with the Wevo. Replaced mine 6 months ago.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 07-05-2007, 02:22 PM
Somewhere in the Midwest
MotoSook's Avatar
Here's an old thread that should be useful:
Carrera Sway Bar Mount Repair and Mod
I went from this:
To this:
Passenger side:
Old 07-05-2007, 02:27 PM
Platinum Member
dad911's Avatar
Re: Member: torn sway bar mount club...
1) Old mounts?
2) Stickier tires?
4) Too-stiff sway** bars for the shocks & springs.
Still had original mounts in my 77 when I sold it in 2003. Spent at least 10 hard years on the track, but PO had put in very stiff shocks & springs.
[** edited to reflect what I meant, not what I typed ]
Old 07-05-2007, 02:55 PM
Model Citizen
herr_oberst's Avatar
Mine didn't tear completely in two, but it was definitely torn. It had also been welded earlier by one of it's PO's.
Replaced with OE upgraded butterfly reinforced mounts - both sides - and no problems since. Okay, it's only been a couple of thousand miles, but hey.
Old 07-05-2007, 03:06 PM
Ayo Irpin, Ukraine!
70SATMan's Avatar
Re: Re: Member: torn sway bar mount club...
Originally posted by dad911
4) Too-stiff torsion bars for the shocks & springs.
What???? Do you mean sway bars to big ????? Torsion and spring is the same thing.
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 07-05-2007, 05:42 PM
Happened on my targa after my second autocross, but I drove around for a couple of weeks wondering what the clunking sound was before I decided to take a peek underneath. I went with the WEVO mounts.
Old 07-05-2007, 06:02 PM
Shaun @ Tru6's Avatar
Re: Re: Re: Member: torn sway bar mount club...
Whoa, what's this? torsion bars are springs? who knew?
Tru6 Restoration & Design
Old 07-05-2007, 06:39 PM
Platinum Member
dad911's Avatar
Ok, I meant to type swaybars. Seems like common 1st upgrade is larger sways, without addressing the rest of the suspension.
Old 07-05-2007, 06:58 PM
Ayo Irpin, Ukraine!
70SATMan's Avatar
WHEW!! I thought I was heading down this road for a second.
That of the modifying the already perfectly designed, no compromises, they knew what they were doing, 37yr old, new technology doesn't matter, I told you so, suspension.
Can you tell I'm increasing my spring rate?
I'm thinking of reinforcing my mounts before slipping on my 18mm sways even though the stock mounts were good enough for the Dr.
Old 07-05-2007, 09:18 PM
