-   -   update on front pan remove/replace (http://forums.pelicanparts.com/porsche-911-technical-forum/355691-update-front-pan-remove-replace.html)
berettafan 07-05-2007 11:42 AM
Well i'm finally making some real progress! i have most of the old pan removed but for the section along the front bulkhead; i didn't get all of the spotwelds on the first try and have some more drilling to do. as you can see it is not so easy to only drill through 1 layer of metal.
a LOT more rust/scale fell out when i finally removed the side parts of the pan and this is just more proof to me that what you see is only the tip of the iceberg! my car did not look that bad on the surface. Battery acid is a nasty thing and i wish a nice case of the runs on whoever failed to deal with leaky batteries way back when in this car.
removing the pan has been, for me, a very difficult process. as the experienced folks will be able to see i took a small shortcut along the lateral supports and broke out the grinder/cutoff wheel combo. the metal where the flange meets the pan on both sides was very thing and basically useless anyways. i will be POR'ing the interior surfaces of the lateral supports before welding things back together.
the only real bummer so far is the fact that i will have to do some manner of fabrication for portions of the lateral supports. if anyone has lateral supports cut out of a solid car i'd love to talk with you! i don't think the work i need to do on the laterals would justify dropping another $400 or so on new supports though. the biggest challenge here, i think, will be replacing the vertical portion of the lateral supports and duplicating the flange which is curved. (if anyone has ideas on that i'd appreciate your input!).
in removing the pan i gave up on the idea of drilling the spotwelds along the underside seam and just ran the angle grinder with cutoff wheel along the inside of the seam. i will still have to grind each spotweld down to remove the excess metal but this is, to me, vastly preferrable to trying to stuff a drill in at the right angles necessary. i have also gone through quite a few dremmel cutoff wheels and find them to be a lifesaver in the tight areas where a 4" grinder is just too big. i did find myself wishing for a nice air compressor and something like a 2" cutoff wheel attached to a small grinder.
http://forums.pelicanparts.com/uploa...1183660833.jpg http://forums.pelicanparts.com/uploa...1183660846.jpg http://forums.pelicanparts.com/uploa...1183660861.jpg http://forums.pelicanparts.com/uploa...1183660881.jpg http://forums.pelicanparts.com/uploa...1183660916.jpg http://forums.pelicanparts.com/uploa...1183660929.jpg http://forums.pelicanparts.com/uploa...1183660942.jpg
Karb 07-05-2007 12:47 PM
berettafan ,
I'm curious about how you're retaining your A Arm alignment. the Arms are hanging out there in the daylight with only the rear bolts holding them. Can they still remain true like this for when you bring in the new sections with bolt holes?
I ask because I'm about to do the same with some shortnose section, and it just so happens your taking on the task before me.
Karb
berettafan 07-05-2007 03:04 PM
Karb i took quite a few measurments from the front bolts to the rear mounting bolts before i started cutting. the arms do have some lateral play but i'm not too worried about it really.
robmog 07-05-2007 03:07 PM
i'm in the middle of replacing my front pan too.
the a arms don't move since the're also fixed by the struts.
it makes aligning the pan easy, just bolt it to the a arms before you trim the pan to fit.
i cut out my lateral supports, it makes fitting the pan MUCH easier.
trying to patch them up will be harder than you realize.
regarding $, how much is your time worth and how fast do you want to get back on the road?
i know the L longitudinal lists for $250. but there is a cheaper alternative available. pm me and we can compare notes.
btw you're doing great.
bob
jevvy 07-05-2007 03:15 PM
You are pretty much where I have got to so feel your pain.
I also struggled with that front section till I cut here:
http://forums.pelicanparts.com/uploa...1183673599.jpg
If you angle the cutting wheel just right you dont risk hitting the outer panel - once I made this cut I had the rest off in about 30 mins as I could deal with each row on its own.
I have no advice on the other bits, I'm yet to cut back to good metal there yet so hope its not too bad.
ZOA NOM 07-05-2007 06:51 PM
I saved a ton of time using a spot weld removal bit in an air drill. I also used a sawzall where necessary. :)
robmog 07-05-2007 07:08 PM
here is where i cut my longitudinal.
it really makes for a minimal weld seam.
and the staggered joint would be stronger than one in line with the pan seam.
and here's a great website to show one way to do it.
you might know it from the early s reg.
http://webpages.charter.net/mayo/Pan_files/v3_document.htm
bob
http://forums.pelicanparts.com/uploa...1183687712.jpg
berettafan 07-05-2007 07:40 PM
rob would love pic of that section removed if you have any. also got your pm; looking forward to some enlightenment here!
robmog 07-05-2007 08:08 PM
pictures
not the best pictures.
you can see my rust problem is a little worse than yours.
i had to remove the battery box: too far gone
i have a lot of hand fabrication yet to do.
you can see how much better the access to welding the pan will be, still have some minor fitting to do this weekend.
bob
http://forums.pelicanparts.com/uploa...1183691051.jpg http://forums.pelicanparts.com/uploa...1183691231.jpg
Tim K 07-05-2007 09:34 PM
I also prefer to grind off the metal at the flange instead of drilling the spot welds. It leaves you with a much nicer flange to work with.
Keep up the good work.
Tim K
berettafan 07-06-2007 05:52 AM
Thanks Tim, i think grinding is going to be the ticket here.
Rob that is a really nice cut on the tank support. Are you using a 4" grinder, dremel or .....?
I am anxious to see a picture of the other side w/ modification you mentioned.
berettafan 07-06-2007 05:57 AM
Rob i have seen Mayo's stuff and studied it for a while. it is a very nice, organized presentation and quite helpful.
sballard 07-06-2007 12:46 PM
berettafan-
I've been following your progress and I am a slightly ahead of you at present. The front part of the pan does have a large number of spot welds. I have to admit that I just drilled through them all. The downside is that when I put in the replacement pan, not all of the holes aligned and I had to fill in several with my MIG welder. I chose to coat the pan and the flanges to which they were welded to with weldthrough primer. If I had to do it over again I would skip the primer and just grind it all down to bare metal. The welds were nasty with that stuff. The idea is that the zinc in the weldthrough will penetrate into the weld and afford some level of protection against rust, but there are lots of opinions pro and con on the forum.
I am currently fabricating the repair pieces for the lateral supports like you will soon do. It's time consuming and requires lots of thought but has turned out to be sort of fun. Be sure to test fit with the tank support before welding them in place. I am away from my home computer at the moment but will post some picts when I return.
Don't make the same mistake I did and try to install the new pan from the bottom - it goes in from the top. I needed to unbolt the transverse support for the A-arms so I could drop them a few inches in order to get the pan properly positioned.
Keep up the good work. The end is in sight!
berettafan 07-06-2007 12:57 PM
uh oh, i was really hoping to just slide the pan in without undoing any more suspension bits. i would be worried about further opportunity to misalign the pan if the a-arms are swinging wild and free.
would love to learn about what you're doing on the fabrication side of things. i did find a website that detailed a simple method of flanging curved metal with a slotted pipe. it looks like it might be worth a try before ordering laterals from Restoration-we never return calls-Design or Stoddard.
and again thank you all for the positive reinforcement! i need it!
robmog 07-06-2007 06:13 PM
here are some pictures of the left side.
you can see where i trimmed and reshaped the weld flange under the battery box.
i'm curious about the fabrication website, could you post the link?
i've got a lot of work to do on the "nose".
bob
http://forums.pelicanparts.com/uploa...1183770577.jpg http://forums.pelicanparts.com/uploa...1183770602.jpg
http://forums.pelicanparts.com/uploa...1183770531.jpg
sballard 07-06-2007 06:22 PM
Unbolting the transverse A-arm support wasn't such a big deal if you've allowed enough room to crawl under there. Certainly a lot easier than taking the A-arms off as some suggest. There are 4 bolts holding it on, and then you can lower it a few inches and wiggle the A-arms around. They are held on by their connections to the other suspension components. When you need to align the pan and A-arms, the support bolts back into place quite easily. However, I needed to use a BF screwdriver to wiggle the steering rack around to get two of the bolts back in. I made a lot of measurements and was worried about misalignments but with the A-arms in place, everything aligned very well.
sballard 07-08-2007 07:10 AM
Here are the images of my fabricated longitudinal repairs. I haven't welded them in yet as I am still fiddling with getting the fit right. They certainly aren't as pretty as the reproductions but their cost was alot higher than the pan and tank support (+$300!) and I figured as long as my repair is sturdy, it doesn't need to be pretty because it will be covered by the tank support. I used 22 ga. steel sheet from Lowes which was as close as I could get to the thickness of the original longitudinals. If you do this, be sure to check the fitment of the tank support periodically. My first effort on the right side interfered with the fit and I had to start over. There are a lot of examples of these repairs on the forum.
http://forums.pelicanparts.com/uploa...1183903636.jpg http://forums.pelicanparts.com/uploa...1183903657.jpg
berettafan 07-08-2007 11:43 AM
how on earth do you drop the pan in from the top? the lateral supports are in the way.
Rick V 07-08-2007 03:46 PM
Eric, I have nothing to offer you having never done this and am not a body man, but looks good. I expect to see your car down here next spring for the 3rd anual Rally in the Valley.
If I can give you a hand give me a call. I'm a decent welder, and a good parts holder.
sballard 07-09-2007 07:58 AM
Berettafan-
My experience was that when the A-arms are dropped a few inches, you can angle the rear portions of the replacement pan down to the front of the lateral supports. When I first approached this, I didn't even consider that the pan would go in from the top because the front of the original pan was spotwelded to the front of the front sheetmetal which can only be duplicated by putting it from the bottom. It almosts fits when put in from the bottom but not quite, and I ended up trimming some of the pan at the rear an attempt to make it fit. I submitted a thread on this about a month ago and several people replied that they installed the pan from the top. I agonized over this for days before I finally dropped the A-arms, squezzed it in from the top, and the fit was much better. Now I wished I hadn't trimmed the replacement pan because I will have to add a little metal back!
If in doubt, try to put in the pan from the bottom and see if you get a good fit. You might have a different pan from mine, which I bought from Restoration Design. But before you start cutting up the replacement pan, I'd try putting it in from above.
Hope this helps.
berettafan 07-09-2007 10:01 AM
so i should unbolt the other end of the a-arms at the cross bar and leave the ball joint intact?
i looked this over yesterday and i think it would be okay as the 'cross bar' doesn't appear to have any adjustment in it so re-bolting into the same exact fit would be easy as pie.
btw, did you guys slosh any POR15 into the rearward portions of the longitudinals?
sballard 07-09-2007 12:25 PM
I haven't done that yet, but it is in my plan. I can look up into the insides of the longitudinals and there is some surface rust, so I thought POR-15 would be good preventative - better than ignoring it. I think that it should be kept a couple of cm away from where any welding will be done. I am not sure about the part of the pan that will be under the tank support. I am now thinking that I should leave the weld-through primer there (I plan to remove the weld-through everywhere else when I prep the surface of the pan for POR-15). Again, I figure its better than nothing. Might be better to get some opinions of people who know what they are talking about on this issue. There are alot of different opinions out there.
Yes, I left the ball joints attached. It still gives you a few extra inches of wiggle room.
berettafan 07-22-2007 01:29 PM
rob, i can't find the darned fabrication site i had looked at but the guy talked about using a pipe with a slot cut in one end to gradually bend a flange onto shaped parts. it LOOKED easy.
berettafan 07-22-2007 05:13 PM
http://www.austin7.org/sheet_metal_flange.htm
found it!
