915 2nd gear woes
My 915 (86 Carrera) is not engaging 2nd gear, probably synchro.
Are these tough to find parts for or tear apart? I've rebuilt 4 speed GM Muncies and Austin Healy transmissions before. I'm newer to 911s, not cars Could it be the clutch cable? Are there good guides or books you would recommend? What brand of syncrhros should I stay away from what other while I'm in there should I do? I know I won't know much till I get her cracked open. ![]() ![]() ![]() ![]() ![]()
Hey Brick.......I've got a 77S with 915 trans. 2nd gear would pop out of gear and wouldn't stay in without holding it in place.
Replaced the synchro and problem solved. Not sure if this helps your issue as I'm not a transmission guy.
Sean M '77 911S Targa Ice Green |
Sometimes the dog teeth on the gear break off , the syncro ring expands and blocks the shift sleeve from engaging the gear. Drive it much more and the brake bands and stop dogs can come loose and go through the gears like a blender. Drain the oil and see if there are little teeth in the pan.
will do... she'll be put back in the garage till I can get to it.
gearhead
Pete Zimmerman has a very thorough and complete wiki of everything you might want to know. Our host here sells all the parts you need.
If you buy teeth get the Rausch and Spiegle version. BRB, there’s a fs ad with the key tools you need. Let me find it…
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 Last edited by Matt Monson; 08-01-2025 at 09:13 AM.. |
gearhead
Sorry. He sold them.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
I learned most of what I know about 915s from Pete's wiki, fellow Pelicans, and the bentley manual How-To: Porsche 915 Transmission Repair Tutorial Part 1 - Porsche Wiki
A few years back I 1-2 hot shifted my SC and busted the stop, wedging pieces of it under the clip. The synchro wouldn't engage so I had no 2nd gear. Easy fix - replaced the broken parts and all set.
-Tony Instagram: @Pablo_the_Porsche | @RuchlosRallye AchtungKraft #002 |
I'll also recommend Pete Z's tutorial. If you're replacing the 2nd gear synchro, you will also want to replace the 1st/2nd shift sleeve. You should measure the installed diameter of the new synchro when installed, and if the measurement is out of spec, replace the engagement teeth (dog ring) on the gear. If the engagement teeth are hammered, that's another good reason to replace them. Good luck with the project,
Kevin Catellus Engineering catelluseng@gmail.com http://www.catellusengineering.com https://www.facebook.com/catelluseng/ |
++ for Pete's tutorial, between it and this forum I got through a comprehensive rebuild of my 915 box, which works really well now.
1981 911SC restomod "Minerva" 2004 Boxster S 2021 Cayman GTS 4.0 manual "Olive" 2014 Cayenne GTS V8 (wife's lover) The slope is not slippery; in fact it is entirely frictionless. |
Driving back to the Garage (store my 911 in an off site garage), I could no longer get the 915 into 4 gear either.
Maybe Clutch Cable...??? I got it back in my garage with 3 gears, I'll get it up in the air and examine how long the pull is. Last edited by Brickwhite; 08-13-2025 at 07:10 AM.. |
gearhead
Start with the shift plate on the bottom. It might have a broken tube on the selector fork that guides the main shift rod.
Drain it first.
I checked a couple things,
The pedal, the cable, shifter and the selector fork. The pedal seems to have some play.. Last edited by Brickwhite; 08-26-2025 at 03:12 PM.. |
I think I broke the thread
test
A couple of things caught my eye. The hose clamp on the shift cup rod is an indicator the fit between the rod and cup holder is compromised. And the shift cup bushing looks to be disintegrated. But as others have alluded to, you risk ever increasing expensive damage by driving it. With Peter Z's guide and your experience, I'm betting you can rebuild it.
1986 Targa Guards Red 2021 MT09 SP |
test
I cannot see this reply?? Admin ?
Try engaging reverse after the clutch has been depressed for a while. If it crunches, then yeah, I guess your clutch cable is likely a major contributor. That old worm clamp on your shifter mechanism is a bit of a worry too...
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
