Blue3.2's Avatar
Lightbulb New Shocks; what else?
I'm about to replace the front strut inserts and rear shocks on my '86 carrera coupe with Bilstein HDs. Any suggestions regarding inexpensive "while you're in there" projects that will compliment the shocks replacement? This is a purely street-driven 911, but it may see the occasional DE in the future.
Thanks.
'86 Porsche Carrera Coupe
Old 07-09-2007, 10:39 AM
Driving member
jester911's Avatar
Probably need to look at all your rubber bushings. Torsion bar, sway bar bushings etc. If it is rubber it probably needs replacing especially if they are original.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 07-09-2007, 10:45 AM
19 years and 17k posts...
azasadny's Avatar
I replaced my brakes, rotors, brake lines and bearings "while I was in there"...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 07-09-2007, 11:51 AM
Re: New Shocks; what else?
Thanks.
Do you really want a thousand guys spending your money ?
Checking the rubber in the sway bars would be my suggestion also. If you've got a wheelbarrow full of cash that needs spending, then there is no end to the upgrades you can make. The rear t-bar bushings at the springplates should be evaluated. You can get an idea if they are worn by looking at how centered they are in the springplate cover as the t-bar end comes through.
Tony G
2000 Boxster S
Old 07-09-2007, 12:26 PM
Blue3.2's Avatar
thanks, guys. With only a thimble of cash, I need to keep this project simple. I was thinking bushings, too, but wondered if there were other essentials I was overlooking. I'll look at the bearings.
As for brakes, great suggestion. I did those last year.
Old 07-09-2007, 01:04 PM
