-   -   Are there any mechanical differences 84-86 3.2? (http://forums.pelicanparts.com/porsche-911-technical-forum/356181-there-any-mechanical-differences-84-86-3-2-a.html)
samsnead 07-08-2007 12:38 PM
I know that they changed the interior in 85 and included Automatic heat control in 86, but are there any mechanical differences?
911mot 07-08-2007 01:41 PM
Aerial moved from front wing to screen for 85
Rot 911 07-08-2007 01:42 PM
Pretty much all stayed the same in regards to the engine. In '86 the seats were lowered and bigger torsion bars.
Gogar 07-08-2007 01:46 PM
Did the front oil cooler change a bit?
lindbhr 07-08-2007 01:48 PM
A/C vents were enlarged in 1986
aigel 07-08-2007 05:36 PM
Bigger sway bars in 86.
George
Gunter 07-08-2007 06:13 PM
Bigger CV's in '85 I believe.
Someone confirm.
tonythetarga 07-08-2007 06:46 PM
Rear t-bars went from 24.4mm to 25mm for 86. Front sway bar went up 1mm also.
I believe the 84 had a tube oil cooler in the front right fender and in 85 it went to the finned radiator style (no fan).
Engine hp and torque were the same for US destination cars at 207hp.
DonMo 07-08-2007 07:47 PM
I believe it was 86 or 87 where the dash could be removed without the windshield being removed. Screws were accessible from inside. Early 84's had 24 pin motronic, later years 28 pin.
Sonic dB 07-08-2007 07:48 PM
drivers side seat is 20mm lower in 86...
drsimonwong 07-09-2007 04:41 AM
In Australia all cars spec'd to accept unlead fuel and compression down and power dropped from 231hp to 207hp.
tonythetarga 07-09-2007 04:58 AM
My 86 is a 24 pins. As I understand it, the 24 pin chip fits 84-87.
edit: (At some point in 87 they switched to the 28 pin, but there are 24 pin Motronic's in early 87's)
samsnead 07-09-2007 07:47 AM
Thanks for the info guys, seems like the main differences are cosmetic and in the suspension.
