What grade of gas do you use.
I have a 75 model with the webers and SSI's and 73 RS exhaust but pretty well everthing else stock,8.5 compression.Is premium fuel really necessary or would 89 or 90 octane be high enough.Premium up here in the Pacific North west is 92 and super is 94.Thanks....
19 years and 17k posts...
Premium (93 octane) in my '74 with Webers. my mechanic recommended it after we switched the CIS over to carbs.
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Banned
93 in my '70
93 in my 71 with Zeniths.
Not to highjack the thread but what is the compatability of the 76 union 100 octane racing fuel with Porsche engines?
Dan |
Senior Member
Higher octane simply protects against detonation. So.....I use it in all the engines I care about.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Super. It's all I've ever used in any of my Porsches...928,914, and the lowly 924. It would make me feel like a bad father to put anything less in my SC!
1984 928s 5 speed |
abit off center
You should use the lowest octane you can, only high enough to protect against detonation.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
93 Why take a chance!!! Use the cheep stuff in everything else. If you are pinching$$$ have an extra salad for lunch and put the $$ in the tank.
Takin' hard left turns
The way I've answered this question in the past is use the lowest octane you can that doesn't cause your car to ping. Higher octane means a slower burn rate. If your engine is designed to run on 87 octane, use 87. The only thing you do by using a higher grade is cause it to burn fuel less efficiently, perhaps to the detriment of your mileage.
It doesn't hurt to use the highest octane, but if your engine doesn't need it, it certainly doesn't help. Smart people, please chime in and tell me if I've got this right. |
Premium - which in California is only 91 octane - in my stock 127,000 mile, unrebuilt '76 2.7 which leaks oil but runs like a scalded dog.
Dan in Pasadena '76 911S Sahara Beige/Cork |
I used 89 prior to my Steve Wong chip... no probs, great mileage. Steve recommends 91 while on the performance chip... so that's what I run now.
-Troy
1986 911 Coupe (Guards Red), Fabspeed Euro Pre-muffler, Steve Wong Performance Chip 2001 Boxster 2.7L (Orient Red), bone stock |
87 in my 911 with PMO. 87 was all that was needed when the car had CIS as well. Running super is a waste of money IMO.
- Tyler 1988 911 Carrera Grand Prix White/Black 2015 Cayenne Diesel Black/ Luxor Beige/Black |
87 octane, 1980 ROW 911SC's have low compression is 8.6:1.
John Adams 1980 ROW 911SC |
Friend of Warren
I am waiting for someone to give a reason why you couldn't use 87 octane in an engine with a 8.5:1 compression ration. Should run just fine.
Kurt V No more Porsches, but a revolving number of motorcycles. |
I use 87. With a CR of 8.5, i dont think anything higher is neccessary.
I use 93 on my 82. I have a 9.8 CR.
James Milton '82 911SC Coupe '07 GMC Yukon '92 Jeep Cherokee Sport (rain car) |
I thought you got "Wonged" recently and would've switched to 93 at that time, too?
'84 Carrera Coupe - B&B Headers and one-out muffler; K&N Cone intake; Steve Wong Chip; Euro height and corner balanced; 171K Miles (9/12) |
I don't have the owners manual in front of me,IIRC it states using fuel with a rating of 92 RON which is typically translates to our octane rating of 89.I will try on my next fill up using the mid grade fuel (89).and see how it runs.I have been keeping a log of fuel mileage since I got the car a couple of months ago and will continue with the different grade of fuel.This is not about penny pinching,this is about using the fuel it was designed to use.Thanks for all of the replys.....
I use 91 here in Az and I get crappy mileage seems every 4 days $15 goes into the tank...Fuel lines, fuel filter, accum and mixture have all been changed and still the gas mileage is down
Frank 1980 SC Cab Conversion (sold) 1974 914 2.0 RIP rear ended Looking for a 996 Silver Cab 2002-2004 |
i use 87 w/8.5:1 & 2.7RS dizzy. Initial is 10deg, total is 35deg.
gas is crappy enough without adding more additives than needed. i also get slightly better mileage. I've also run 100+F deserts with no problem. i think if the issue makes you nervious use high test.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
