-   -   Ring and Pinion mesh pattern (http://forums.pelicanparts.com/porsche-911-technical-forum/356456-ring-pinion-mesh-pattern.html)
lv2race 07-09-2007 08:47 PM
I just set the ring gear in pinion shaft in my 901 transmission and then marked both the ring gear and pinion shaft with blue marker. Can anyone describe to me what a good mesh pattern should look like on the ring gear and pinion shaft?
Thanks for your help.
Rob
Paulporsche 07-10-2007 05:54 AM
If you search you will find a really good thread on R+P rebuilds. I think it was by RarlyL8.
vntgspd 07-10-2007 08:18 AM
Do a Google search under "ring & pinion setting" and you will find lots of good info from the 4x4 guys. Great pictures included. I don't think this is something that you can "explain".
Good Luck!
David 07-10-2007 08:57 AM
I'd also use something like a thin yellow or white paint rather than marker.
lv2race 07-11-2007 12:02 AM
Guys - thanks for the help. I've got the information I need.
