Porsche Owner
mark4ton's Avatar
Porsche Crest speedometer stops working
alright so my speedometer on my 87 carrera decides to work when it wants to...then it doesn't work randomly...I'm not sure what it could be...and i have no clue how to take it out? help please. thanks.
mark.
1987 Carrera - 2008 Cayenne Turbo
Old 07-10-2007, 01:01 AM
Mine was the same. It turned out to be the sending unit. Very easy fix. A couple of shops tried to convince me that the speedo was bad...not.
2001 Z3 M Roadster
1988 911
2008 WRX
1988 E30 M3
Old 07-10-2007, 05:43 AM
Porsche Owner
mark4ton's Avatar
sooo....how do i fix it?
Old 07-10-2007, 12:00 PM
I highly recommend Bentley's Repair Manual for the 911. I believe Pelican carries it or you can get one at Amazon.com. I can't imagine owning an older 911 without it. Well worth the 100 bucks or so. It will show you how.
Also, you can look up "sending unit" for your year car and view the part and description on this site. It is a simple plug-in deal.
2001 Z3 M Roadster
1988 911
2008 WRX
1988 E30 M3
Old 07-10-2007, 12:39 PM
Make sure you check your grounds and battery connections. Simple to do and may solve your problem. Did for me. Good luck.
87 blk coupe
Old 07-10-2007, 12:52 PM
Remember
The Turk's Avatar
The first thing to do is pull the speedo out of the dash and make sure you have 12 volts with the key on at the “+” and “-“ terminals on the speedo.
If you have 12 volts then you need to check your sender, here’s how you do it.
Disconnect the wire going to the “31b” terminal, hook a multimeter set to the lowest ohm setting between the wire that was on the “31b” terminal and the “-“ terminal.
Start the car and back it up or move it forward, you should see 8 closures for each revolution of the rear wheels.
Let us know what happens.
Gary
1975 911S G50 3.5 Twin Turbo
Old 07-10-2007, 02:57 PM
