1982 SC 3.6 fuel pump wiring help
Hi guys, its been 20 years since I put the 3.6 in my 82 sc. Yep lost the Timmins wiring guide. ( Ha Ha I have only driven it 500 miles since 2002, flat lost interest, I'm back).
Had some fuel starvation when I last drove it, yep been awhile. Normal stuff gas has been it forever so I drained the tank. Test the old fuel pump yep rattles with low pressure. Anyway, I cant remember the wiring and can not find the chart. Anyone have one? when I took it off. Green to + Brown to - Black the end was cut off. I think the black isn't used, it looks like the green comes from the Timmins harness. I will have to pull it all apart to check. I think it goes to the CPU that does cold start and keeps the pump running when you let go of the key. Thanks, any help would be appreciated, Kevin
