rhymes with targa
Sticker Residue removal from Targa Rear Window
I have a couple of stickers I would like to remove from the inside of the rear window on my Targa. I carefully peeled one of them back a little bit and it's leaving sticker residue on the inside of the window. I plan to peel the sticker in a downward or upward motion in order to go with the trace line path and prevent a trace line from pulling off the window. My concern is I don't want to use a cleaner that will un-stick the defrost trace lines from the window when removing the sticker residue. What should I use?
I,m not sure how you call it in english but i use white oil as used in camping lamps. But be carefull on the rubber parts because it will leave white spots, but if you mask them first it should work fine. Or use sticker remover offcourse but allways try a small piece first !
Try to warm the sticker first with a blow dryer first and you will take most of the sticker off without leaving the sticky film. Cheers,
87 Carrera Backdate |
WD-40
KC 88 Guards Red Targa (sadly sold )2005 Boxster S 1st Porsche 73 914 (long gone) |
sudo apt-get purge 930
Goo-Gone
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
rhymes with targa
Thanks all. Looks like the usual suspects work here...
19 years and 17k posts...
I used mineral spirits and it removed the goo and left the defroster lines in place. good luck!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
